06-01-2013, 12:03 PM | #1 |
How hard to replace the multi-function switch?
The wipers on the K30 I just bought is set up on a toggle switch under the dash. The MF lever is broken and needs replaced. Everything else as far as bright switch, turn signal, and cruise seems to work just fine. I have never had to replace one of these so I don't know what all is involved.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
06-01-2013, 05:43 PM | #2 |
Re: How hard to replace the multi-function switch?
How does the switch come out. Do I have to tear down the column to get it off.
06-01-2013, 05:59 PM | #3 |
Yes I believe you have to take the wheel off and the plate that's behind the wheel. The switch is held on with one screw and the wires for the switches are fed through the column itself.
1985 C10 2004 Avalanche |
06-02-2013, 12:06 AM | #4 |
The lever itself just pulls straight out if I remember correctly. You have to remove the steering wheel and locking plate. Both are easy to remove with the right tools which are available cheap at Autozone. The hardest part is feeding the wires through the column. I had the column out of the truck and it was still a pain to feed the wires through.
Posted via Mobile Device |
06-02-2013, 09:06 AM | #5 |
Maybe I can tie a string to the end of the connector before I pull the switch out. That way maybe I can just pull the new wiring back through the column with the string. Not sure if it will work but worth a try. I was hoping I didn't have to pull the steering wheel and plate underneath it. Oh well.
06-02-2013, 07:24 PM | #6 |
Dozens of articles online on rebuilding a Saginaw steering column
06-02-2013, 08:07 PM | #7 |
Moderator
That's what I'd do...
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
