Old 01-16-2014, 02:24 PM   #1
kinger62
1988 k2500 defrost problem
Hi, my 1988 K2500 will not blow air through the windshield defrost vent. The actuator motor opens and classes the proper doors to get air on the floor and through the dash vents. When I push the button to get the air to defrost I can feel the air blowing on the door windows through the little side vents but I get none on the windshield itself. Does this mean the vent is blocked? Any suggestions for troubleshooting? Thanks!
kinger62 is offline   Reply With Quote
Old 01-16-2014, 03:01 PM   #2
sntrym95
sntrym95's Avatar
Re: 1988 k2500 defrost problem
The linkage is above the area between the left side of the transmission hump and the gas pedal. It's up in there and tough to get to, but you can watch it and fix it if needed. Just be patient. Sometimes the end of the linkage rod pops out of the sleeve. You'll know what I'm talking about once you see it. Make sure you have a bright skinny flashlight.
Mike
sntrym95 is offline   Reply With Quote
Old 01-16-2014, 03:49 PM   #3
kinger62
Mike, do you mean at the actuator motor there? I replaced that unit and I can watch the floor vent door open and close. From the dash level (I removed the cubby next to the glove box) I can see the dash vent door open and close. Is there a third door I can't see? Thanks!
Old 01-16-2014, 04:49 PM   #4
ChevyTech
That is the actuator for the temperature. Not the problem!
Yes, the fresh air intake AKA max AC door. Not the problem!
Do as mike said.
There is more then one door being moved by that actuator next to the gas pedal. Study it as it moves.
Old 01-16-2014, 05:34 PM   #5
kinger62
To clarify, I have found two actuator motors: one that operates the cold/hot air (this is working properly) and one that operates the bypass doors to determine where the air comes out: dash, floor, or windshield. When I replaced the actuator that operates the bypass doors I can see two doors moving...one under the dash allowing air to go to the floor, and one "mid-dash level" that lets air out the dashboard vents. When I push "defrost" both of these doors close so air cannot get through the floor vents or the dash vents. At this point air does come out of the small defrost vents that will warm the windows on the doors, but nothing comes out of the main dashboard defrost vent. Shouldn't air be diverted to the defrost vents at this point? This is why I'm wondering if the vent could be somehow blocked, unless there is a third door I'm not aware of. If so, where physically is it located?
Thanks again!
Pete
Old 01-16-2014, 08:12 PM   #6
ChevyTech
The actuator by the gas pedal is the only actuator that you should be looking at for this problem.
The two doors moved by the actuator by the gas pedal must work in unison to direct air flow. If out of adjustment they can bind.
Do you pile stuff on the dashboard?
If something fell down the defroster vent it could be blocking movement.
One truck I helped someone with had honey on the door for the defrosters and it was stuck.
Old 01-16-2014, 08:26 PM   #7
kinger62
Thanks, ChevyTech. The actuator you refer to seems to be working properly. For the floor heat, the floor door is open and the dash door is closed. When I select the vent position, the floor door closes and the dash door opens. When I select defrost both these doors close, I'm assuming to direct the air to the top vent. Is there a third door in the system I can't see? If so, from where can I access it? I can hear the air trying to escape at the floor because it can't get out up top.
Old 01-16-2014, 08:56 PM   #8
ChevyTech
Yes there is a third actuator.
Leave it alone.
It is, the fresh air intake AKA max AC door. Not the problem!
If you are having trouble with the mode doors you should not even think of messing with the fresh air door.
must work in unison
Did the linkage come out of the adjuster when you were working on it?
Old 01-16-2014, 09:08 PM   #9
kinger62
I thought of that but I don't think so. As I said, the floor and dash bypass doors are moving so the actuator is working.
Old 01-16-2014, 09:22 PM   #10
ChevyTech
I went and pulled a manual out and it is worthless.
I will dig and see what I have for saved links and if any of them still work and post back.
Old 01-16-2014, 09:30 PM   #11
ChevyTech
I did some more looking and the service manual is worse then worthless, it has the actuators labeled wrong. Now I see why people get them so confused. If it is wrong in the manual, every place that uses the GM service manual as a source will be wrong.
I am still looking for more information.
Old 01-16-2014, 09:31 PM   #12
ChevyTech
http://67-72chevytrucks.com/vboard/s...d.php?t=571882
Old 01-16-2014, 09:36 PM   #13
ChevyTech
Here is the other actuator that you did not find.
But leave it alone.
http://www.chevytalk.org/fusionbb/sh...php?tid/170970
Old 01-16-2014, 09:41 PM   #14
ChevyTech
Old 01-16-2014, 09:47 PM   #15
ChevyTech
http://www.chevytalk.org/fusionbb/sh...cd9ed79a28da4/
Old 01-16-2014, 09:50 PM   #16
kinger62
Hey, this is great! Do you have the corresponding list of part names for this diagram?
Old 01-16-2014, 10:04 PM   #17
ChevyTech
Must be to many people on the board tonight. I keep getting this message:
“The server is too busy at the moment. Please try again later.”
I don't have the corresponding list. I have many links to check.
That is all I have found so far.
I also have some more manuals to look in.
My training manual shows the shop service manual is wrong. Typical GM screw up!!!
Move the controls from heat to defrost on your truck, while you watch part #36 move and make sure the spring on part #29 is not compressing so part #36 ends up not moving like it should.
Old 01-16-2014, 10:30 PM   #18
ChevyTech
There is an illustration at this link where at least the actuator motors are labeled correctly.
http://www.justanswer.com/chevy/3pb6...e-control.html
Better one
http://www.justanswer.com/chevy/4ngh...ing-sound.html
Old 01-16-2014, 10:32 PM   #19
kinger62
Thank you. I owe you!
Old 01-16-2014, 10:53 PM   #20
ChevyTech
You’re welcome. A thank you is always appreciated.
Welcome to the message board!
Old 01-16-2014, 10:58 PM   #21
kinger62
Thanks! I plan to make use of it. I've got a nice truck but it's got issues!
Old 01-17-2014, 11:34 AM   #22
ChevyTech
I am going to see if I can hot link an illustration in, so we can us this thread for future reference.
Source of illustration if linking does not work:
Old 01-17-2014, 12:23 PM   #23
kinger62
Thanks again, ChevyTech. I'm going to head out now (its warm enough to work outside!) and see if I can track this down. Looks like, but one of the diagrams, the door (valve) actuator motor is controlling three doors, not two. I'd only looked at the bottom two. I'm going to check the third now, as that must be the culprit.
Pete
Old 01-19-2014, 05:59 PM   #24
kinger62
Well, thanks to your diagrams I discovered the problem. By laying on the floor and looking up under the dash with a flashlight while pushing the defrost/heat button I could see the defrost door wasn't opening. I sprayed some lithium grease up there while moving the door worth a long screwdriver. It worked. Now it opens and closes like it should. Good thing I don't need to replace the door as it seems the only way is to remove the dash first! I really appreciate your help.
Old 01-19-2014, 06:32 PM   #25
ChevyTech
Excellent!
Thanks for letting us know what fixed it.
Like I said, a previous problem like yours was caused by honey on the door.
Yes, the defroster door it is not the easiest item to get to. Not the kind of a repair that someone wants to do, in the north, in the winter, unless they have a heated shop.
