Old 05-26-2023, 01:17 PM   #1
mm1077
Active Member
mm1077's Avatar
Clutch fan upgrade
What clutch/fan setup is anyone using on a long water pump with factory shroud (standard Sbc 350 non-AC truck) I’ve got the original 4 blade fan now and it cools great but I’d like to quiet down the noise aspect. I’ve read through the old posts and everything I can find as far as part #s was used on a short pump setup. Or does it even really matter? Thanks-Mike
mm1077 is offline   Reply With Quote
Old 05-26-2023, 02:31 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Clutch fan upgrade
Are you sure you have a long WP? This thread suggests your truck should have a short WP. https://67-72chevytrucks.com/vboard/...d.php?t=826073
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-26-2023, 03:27 PM   #3
mm1077
Active Member
mm1077's Avatar
I’m not sure at all : ). I searched online and something made me decide that I had a long pump lol.
Old 05-26-2023, 04:18 PM   #4
kwmech
Short pump. If you had a long pump, the fan with a clutch would be rubbing on the radiator
Old 05-26-2023, 04:35 PM   #5
72SB
A 7 blade 18" fan and Fan clutch
This is the fan I bought. SBC, short WP
https://www.npdlink.com/product/fan-...1967&year=1967
and Fan Clutch
https://www.npdlink.com/product/clut...%3D0%26year%3D
the center of fan blade is about 2" from face of WP pulley fan clutch bolts to. If you needed the fan to be further out you can just add a spacer or find a fan clutch with a longer neck
72SB is offline   Reply With Quote
Old 05-26-2023, 05:10 PM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
and Fan Clutch
mm1077 -- Yep, you have a short water pump.
72SB -- That fan looks perfect, same as my OEM fan.
A question about that clutch, if you don't mind. Do you know if it's standard duty (front fins around the outer perimeter only), or is it heavy duty(fins across the entire front)?
Either should work OK for the OP since he doesn't have AC. I prefer a HD clutch just for the additional cooling -- necessary or not.
EDIT: Link to Hayden's site showing differences between standard-, heavy-, and severe-duty clutches. https://www.haydenauto.com/en/produc...-types/thermal
- Mike -
RIP El Jay
Old 05-26-2023, 05:18 PM   #7
RustyPile
RustyPile's Avatar
If that's pictures of your water pump, that "something" was wrong.. Referencing your pictures, when installed, the back of the short water pump almost touches the timing chain cover. On the long water pump, there is a considerable gap between the back of the pump and the timing chain cover.. Enough gap to actually put fingers in the gap..
The two pumps aren't interchangeable as the pulleys on the pump would not align with the other pulleys..
RustyPile is offline   Reply With Quote
Old 05-26-2023, 06:53 PM   #8
mm1077
Active Member
mm1077's Avatar
Thank you for the replies and confirmation of what I’ve actually got : ). I’m pretty confident in ordering the correct parts now
Old 05-26-2023, 06:53 PM   #9
72SB
mm1077 --
fins are also on front of fan clutch. My WP is also HD, Airtex Wells I got on Rockauto
I had the asymmetrical 5 blade and it was OK until I get stuck in traffic for 30 min so I went 7 blade, problem solved. The 5 blade was fine with my 327 but the BPE 355 wanted more fan
NPD is not far from me so I bought my 5 blade, FC I had but the 7 blade did not bolt up to the FC I had so had to get this one while I was there
Old 05-26-2023, 06:54 PM   #10
72SB
just make sure the FC you get fits the fan you get
