Old 01-14-2019, 12:56 PM   #1
ZacharyDouglas1992
Converting to power windows 83 crewcab
Does anyone here have pictures handy of where they drilled holes to run the wiring for power windows? Or pictures of where the holes are on a factory truck with power? I have power doors on the truck now and a full brand new harness... Just need to know where I should be routing the wiring. Anything is helpful.
thanks in advance!
1967 CHEVELLE MALIBU 427/700R4
1971 CHEYENNE 10 350/350
1983 GMC K3500 454/400/205
1987 R10 TBI 350/700R4
2014 CRUZE 2.0 TURBO DIESEL
ZacharyDouglas1992 is offline   Reply With Quote
Old 01-14-2019, 02:22 PM   #2
blindbug
Re: Converting to power windows 83 crewcab
https://youtu.be/cDw3NFThLkQ?t=392
This is the stock location in a video form for a standard cab. I'm unsure if the rear door on the crew cab would be in a different location, but I would expect it to be roughly in the same location. Hope this helps for the front doors, at least.
blindbug is offline   Reply With Quote
Old 01-15-2019, 01:57 AM   #3
Cabnchassis
You'll need the power lock solenoid that mounts under the dash. If you dont have it, they're difficult to find replacements for, so grab a spare when you do if they aren't easy to find in your area. The one from my donor lasted a few weeks and took a few more to replace
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
locks, power doors, windows, wiring
