Cargo lamp bulb socket
![]() Join Date: Jun 2014
Re: Cargo lamp bulb socket
Hi Peter - looks like you're missing the "guts" for the bulb holder. Parts catalogs don't show it as a separate replaceable assembly piece so I'm thinking it must be an integral part of the base. If you have a LMC catalog it's useful for figuring these kinds of issues out. If you don't have one, get one.
I have a couple of these at home, I'll look at them tonight to confirm it is as I'm speculating. RP |
![]() Join Date: Mar 2012
I bought a new cargo lamp from LMC years ago, comes with everything you need , the only issue are.
1 the screws rusted after about a year 2. the rubber boot/ moulding dose not quite fit the curve of the roof line, and it is rather hard, I let it set out in the sun to soften up and then installed it hot and tight and it took shape pretty good But I still have those ugly rusted (imitation stainless screws)
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
Thanks gents, I knew someone had to have seen this before. I wonder if I can just buy one of the cheap generic eBay sockets for this bulb size and use it as the "guts".
The lamp itself is pretty well worn, but a new piece would not only cost a bunch but look out of place on this crusty truck... |
if yer crafty, take a stroll through the help section of a well stocked auto parts store like napa or pep boys and pick out the closest fitting lamp holder socket and fit it to the old fixture.. rtv adhesive, jb weld, epoxy cement, etc. may work for attaching it in there without drilling holes.. low wattage incandescent or LED will help keep things cooler and hopefully last a little longer without melting everything..
good luck! |
