Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 02-03-2018, 03:02 AM   #1
jhngardner367
jhngardner367's Avatar
Gear lube for 2002 S10,5 speed manual trans
Having trouble finding a substitute for the GM recommended lube,P/N 9985648.
I was told that the Pennzoil Sychromesh oil,is the same.
What do Y'all think/recommend ?
Always expect the unexpected,....but don't expect the unexpected to be the unexpected you expect !
I'm busier than a one-legged cat,in a sandbox!
Veteran..and proud !
I can't fix what ain't broke....you want I should break it?
jhngardner367 is offline   Reply With Quote
Old 02-03-2018, 11:27 AM   #2
95 S_Trucker
95 S_Trucker's Avatar
Re: Gear lube for 2002 S10,5 speed manual trans
Pennzoil will work.
I usually just order gm stuff from the dealer. You have an NV1500 if you have a 4 cylinder. You have an NV3500 if you have a 6 cylinder. The part numbers below may be superseded.
95 S_Trucker is offline   Reply With Quote
Old 02-13-2018, 12:21 AM   #3
406flyfish
Ames oil also makes syncomesh fluid that works. I’m not sure of the cost it might be more than gm fluid.
406flyfish is offline   Reply With Quote
