Old 03-04-2024, 11:03 AM   #1
1998c1500
1998c1500's Avatar
Connector help
Any idea what this plugs into? It is in the transmission harness, But I can't seem to locate the other end
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
1998c1500 is offline   Reply With Quote
Old 03-05-2024, 02:03 PM   #2
Second Series
Second Series's Avatar
Re: Connector help
Wire colors? Is it 4WD? Output speed sensor for 4WD lt blu, and Green/yellow.
It looks like the tail light connector, Green, brown, yellow, black.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
Old 03-11-2024, 03:53 PM   #3
1998c1500
1998c1500's Avatar
Re: Connector help
1998 c1500 2wd. Colors are hard to make out. Itis in the harness right above the transmission.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
Old 03-11-2024, 05:36 PM   #4
Accelo
Accelo's Avatar
Re: Connector help
looks like an 02 sensor plug?
Accelo is offline   Reply With Quote
Old 04-01-2024, 10:22 AM   #5
1998c1500
1998c1500's Avatar
Re: Connector help
It turns out that it was not used. I am guessing it was for a transfer case. I noticed this as the plug has a dust cover that exposes the connections.
1965 C10
1967 Camaro
1998 C1500
2011 Colorado W/T
