Old 04-20-2017, 04:55 PM   #1
bbluma
Rust Help, Which Pieces and Where To Buy
Hey ya'll, im about to tackle fixing the rust on my truck and need some advice on exactly which parts to get, and best place to get them. Rust is cab corners, rockers, and little bit of the floor. I added some pictures for a few. Its not terrible, and its the common places. Previous owners did try to do some cheap rust solution, and its better to just cut it out and put in new pieces.
So i would just like some advice on which parts to exactly get and best place to get them. Thanks in advance.
bbluma is offline   Reply With Quote
Old 04-20-2017, 07:13 PM   #2
oldusafmsgt
oldusafmsgt's Avatar
Re: Rust Help, Which Pieces and Where To Buy
Looks like outer floor pans, possibly cab supports, and outer rockers. Might be more once you start cutting out the bad stuff, usually is. All reproduction sheet metal comes from one place, one factory, in China. All suppliers get the same parts, and quality is hit and miss. All repro sheet metal will need some tweaking. Shop around for the best deal, I've found Classic Truck Parts in Missouri are reasonable on prices and shipping, and have always provided great customer service when I needed it. Good luck and Start cuttin' !
1960 Chevy Apache10 Short Fleetside
1961 Chevy Apache10 Short Fleetside
1961 Chevy Apache20 Fleetside
1963 Chevy C10 Short Fleetside
1965 Chevy C10 Short Stepside
1965 Chevy C10 Long Fleetside
1966 GMC 1000 Long Fleetside
1966 Chevy C10 Short Fleetside
oldusafmsgt is offline   Reply With Quote
Old 04-20-2017, 07:36 PM   #3
bbluma
Do you think it would be good to just get this piece? Covers that good part of inner rocker, part of seat hump and floor? and then get the outter rocker
https://www.topbananaparts.com/drive...r-section.html
Old 04-20-2017, 10:22 PM   #4
Classic v6 GMC's
Classic v6 GMC's's Avatar
Looks like you need the one you posted and maybe some of these
https://www.topbananaparts.com/passe...oor-pan-1.html
https://www.topbananaparts.com/oem-s...support-1.html
https://www.topbananaparts.com/passe...b-support.html
https://www.topbananaparts.com/passe...ot-well-1.html
https://www.topbananaparts.com/passe...ler-front.html
https://www.topbananaparts.com/drive...ker-panel.html
You might not need all of them but that is what it took on the last cab we did.
I usually get my parts from LMC or Classic Parts because they are close by.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD
1966 GMC Long Step
1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6
1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435
1960 GMC Custom
1968 GMC 3/4 ton 4x4 Short Bed
1962 K20 Tow truck
1961 GMC Extended Suburban Panel and a few more
Classic v6 GMC's is offline   Reply With Quote
