11-01-2008, 09:52 PM | #1 |
Another upgrade............hood latch!!
Have you ever been driving down the highway and had your hood to fly open on you? I have and it's down right scary! That's not something that I want to experience again so I decided to upgrade to something a bit more modern. The solution? I used the latch assembly from my son's '97 that I'm going to be parting out. I figured that I may as well see if there were anything I could salvage before I let it go. I still have a few bugs to work out but it looks very promising.
upper latch I'm working on different shims to get it to fit flush. That's a 1/2" plywood block but it's a tad too tall. I'll probably experiment with a 3/8 and 1/4 piece to mock it up. lower latch under dash opener hood closed
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. Last edited by mobileortho; 11-12-2008 at 04:01 PM. |
11-02-2008, 09:16 AM | #2 |
Re: Another upgrade............hood latch!!
nothing like bringing the truck into the 21st century! nice upgrade.
11-03-2008, 01:05 PM | #3 |
11-03-2008, 05:55 PM | #4 |
mmm! link won't work for me.
11-03-2008, 10:15 PM | #5 |
Wouldn't work for me ether.
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
11-04-2008, 12:40 PM | #6 |
Sorry, lets try that again.
http://www.thehoffmangroup.com/autol...so?itemid=BCTR I've NOT tried this myself but I'm seriously thinking about it...... |
11-10-2008, 11:59 PM | #7 |
Worked on the assembly some more this weekend. Turns out that once everything was bolted in, there was no need to shim the upper plate.
dash mounted opener lower plate upper assembly
11-11-2008, 12:32 AM | #8 |
That idea is growing on me as I have had the hood blow open once in the big middle of Wyoming. 120 louvers saved the day by reducing the wind drag and allowing me to see through them.
The S-10 Blazer sitting out here may be a doner candidate if someone doesn't come along and haul off the front end first. |
