Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > FAQ Truck Tech > Engine and Drivetrain
Old 03-27-2009, 10:57 AM   #1
Houston54
TH350C - How to Set Up the Lockup
I have seen several threads asking how to wire up the lockup feature of the TH350C without having to purchase one of the expensive kits available from several sources.
The following are the AC Delco part numbers for the original components used for this transmission type.
Vacuum Switch - AC Delco # 212-331, GM # 14032087 (Current Pricing at XL Auto Parts $35.31)
Brake Pedal Switch - AC Delco # D850A, GM # 25524845 (Current Pricing at XL Auto Parts $11.32)
Vacuum Check Valve - AC Delco # 214-479, GM # 14020691 (Current Pricing at XL Auto Parts $19.91)
The plug for wiring to the vacuum switch is not available new to my knowledge and I could not find one at the local salvage yard. To make the connection I soldered the wires directly to the connector lands on the switch using shrink tubing to provide some strain relief protection.
One of the wires from the vacumm switch goes to a keyed 12V source while the other wire goes to the brake switch.
The brake switch has four poles on it. Two are for the lockup function and the other two are for the tail light circuit. I had to figure out which was which was trial and error. Once you get that figured out and connect the switched 12v from the vacuum switch you will need to run aother wire from the other pole down to the solenoid switch on the transmission. The solenoid switch the rebuilder put in my trans only has one pole on it as the original is difficult to impossible to find. The replacement switch is from a later model GM lockup trans. It may be the 200R4 switch but not sure. If I get by the rebuilders shop again I will ask.
The other side of the vacuum switch consists of a male vacuum connection which I tubed to the intake manifold vacuum tree. The small check valve was inserted between the switch and the manifold.
That is it. Total parts cost is $66.54 plus tax of course.
I tried sourcing these parts directly from the local Chevy dealer and found the prices much much higher. Your results may vary.
I mounted the vacuum switch on my firewall and to date the system has performed flawlessly.
Hope this helps someone else out there.
Last edited by Houston54; 03-27-2009 at 01:12 PM. Reason: Added current parts pricing
Houston54 is offline
Old 03-28-2009, 01:27 PM   #2
clay68c10
clay68c10's Avatar
Re: TH350C - How to Set Up the Lockup
I bet this would work for a 700R4. Anyone know if it will?
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO
http://67-72chevytrucks.com/vboard/s...d.php?t=788602
93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday...
05 Jeep Wrangler Unlimited. 3” lift & 6-speed
02 E320 the insurance total “free car”
13 Tahoe LTZ
clay68c10 is offline
Old 04-20-2009, 11:34 PM   #3
C-10 simplex
Can the trans be run without the lockup feature without damaging the transmission?
C-10 simplex is offline
Old 04-21-2009, 02:02 PM   #4
Houston54
Yes it can.
Old 04-22-2009, 10:08 AM   #5
C-10 simplex
Also, i know that the computer(or something) will lock it up (mine is an 83 1/2 ton) and when you press the brakes it will unlock.
What i'm wondering what the vacuum thing is for----which i partially understand will unlock it upon deceleration. Why is this nessesary(if it all)?
The reason why i'm asking is i will have to swap motors (long, sad story why--another topic) and the "new" motor has a different manifold with less/different/non-original vacuum line patterns.
Old 04-24-2009, 02:18 AM   #6
Lugnut64052
Middle-aged Curmudgeon
Lugnut64052's Avatar
Pretty sure it will. I believe you could use the same setup to lockup a 700R4, a 200-4R or a 350.
Houston 54, thanks for the Delco part numbers. Sure simplifies things.
Bret
Check out the site's Truck Tech FAQ.
Be a site supporter.
My more-or-less pathetic build thread.
Board members I've met:
Longhorn Man
Dieselwrencher
jholley
big mike71
Lugnut64052 is offline
Old 05-09-2009, 03:58 PM   #7
71Farmtruck
Junk Junkie
71Farmtruck's Avatar
http://www.73-87.com/7387garage/drivetrain/lockup.htm
Mike
71 Chevrolet C-10 Short Bed Stepside
81 GMC 1500 Sierra Classic Long Bed
71Farmtruck is offline
