11-02-2022, 12:22 AM | #1 |
What Alcoa hub bore size on 1985 Dually
I just dropped off my Alcoa wheels at the polisher and while I made sure the bolt pattern was correct, I didn't factor in the hub bore. I know it is supposed to be 4.56 but searching Alcoa wheels, I don't see this as a choice. If someone can get me an answer ASAP I would appreciate it as it is going to cost $300 to have them done and they will be done by Friday so I want to catch them in time. Any Help is appreciated
AZPartsLocators on Instagram 1972 Cheyenne Super Short Bed big block "Blackie" 1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog" 1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck. |
11-02-2022, 12:24 AM | #2 |
Re: What Alcoa hub bore size on 1985 Dually
I only see 4.88 and 4.60 wheel bore options for Alcoa wheels
11-02-2022, 07:00 PM | #3 |
A stock dually steel rim is 4- 9/16'' or 4.562 so the 4.6 should work out just fine as the early stuff was lug centric not hub centric. AND you wouldn't want the aluminum tight against the steel hub anyways (unless you butter it up good with anit-seize) for the corrosion factor
11-02-2022, 08:36 PM | #4 | |
11-03-2022, 03:33 PM | #5 | |
Desert |
12-14-2022, 01:29 PM | #6 |
These wheels and I came to just over 4.5 in so it looks like I have the right ones at least
