Old 05-19-2012, 02:58 PM   #1
Tinsmith
Porterbuilt control arm help
I purchased some upper and lower control arms, Was putting everything back together on the front end but the upper control arms ended up hitting the stock upper crossmember that they bolt to. They are not able to fully seat aganist the bracket, there is those 1/2 thick spacers from the factory arms but that is still not enough. if I make a 1'' thick spacer will that effect the caster,camber? if it comes down to it I could shave some metal off the bracket, but I just had them powdercoated will post some pictures but need to go get a connecter for the phone to upload pictures. also the holes on the crossshafts on the porterbuilt arms seems a little large for the factory studs, is there a difference for the different years 67-72 73-87 cause i upgraded to 73-87 steering.
thanks in advance for any help
Tinsmith is offline   Reply With Quote
Old 05-19-2012, 04:38 PM   #2
PBFAB.COM
PBFAB.COM's Avatar
Re: Porterbuilt control arm help
Shoot me a text and I will get in touch to answer all your questions!
480-326-6303
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 05-19-2012, 11:24 PM   #3
Bennett68C10
Bennett68C10's Avatar
Any resolution on this, I'm about to install mine and hope to not have the same problem
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 05-19-2012, 11:31 PM   #4
PBFAB.COM
PBFAB.COM's Avatar
He hasn't been in touch with me yet. Shouldn't be any thing to worry about. Hundreds of sets out there on factory cross members.
When its set up at proper alignment, the shaft should clear the gusset he's referring to.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-19-2012, 11:48 PM   #5
Bennett68C10
Ok thanks Nate, I'm a bit of a worrier lol. Hoping to install mine tomorrow.
Keith
66 Suburban
IG: bennett68c10
Old 05-20-2012, 02:32 AM   #6
andrewmp6
I trust nate its rare when he makes a mistake but when he does he goes out of his way to fix it.
Old 05-20-2012, 10:24 AM   #7
PBFAB.COM
PBFAB.COM's Avatar
Actually, I made my first mistake just the other day! LOL
There shouldn't be any issues at all. But if a concern ever arises, just get in touch and we will get ya taken care of!
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 05-20-2012, 11:09 AM   #8
Rochlow
That's customer service right there!! What owner of a company would respond to a customer's concern at 6am (his time) on a Sunday!!
Rochlow is offline   Reply With Quote
Old 05-20-2012, 07:23 PM   #9
Tinsmith
Hey thanks for the quick response, Been a little busy, blow up the tranny on the daily driver yesterday going to get the ball joint press, for the control arms. so have to put this on the back burner for a few days. Will phone in to you on monday, if you are open? cause it is a holiday here.
thanks Jonathan
Old 05-20-2012, 11:37 PM   #10
Tinsmith
So here are some pictures of the arms. Thanks Jon
Old 05-22-2012, 09:10 PM   #11
Tinsmith
I ended up just shaving the gussets down to clear. Like they said on the phone all these trucks seem to have different deficiencies in different areas, sucks that they were just powdered coated. Had to touch them up but you can't tell unless you are few inches away. Over this little bump, on to the next few......(hundred) .I will say it is so nice working with new parts. Yet alone quality parts from Nate. Like putting the lower ball joint in was literally a five minute job for both.
Old 01-10-2015, 08:28 PM   #12
calvin78612
calvin78612's Avatar
I know this is an old thread but does anyone know if the highlighted area gets one of the washers that comes w/ the PBFAB upper control arm ?
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 01-12-2015, 11:18 AM   #13
PBFAB.COM
PBFAB.COM's Avatar
No washer gets installed there.
The crush tube will bottom out on the machined collar of the shaft.
Make sure the bushing shoulder seats against the outer edge of the control arm pivot tube (the machined sleeve that the bushing slides into) then tighten her down until the crush tube seats against the shaft.
Fee free to send me an email with any questions! Tech@pbfab.com
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-12-2015, 11:33 AM   #14
calvin78612
Customer service at it's best !! Thanks guys.
84 step side
87 swb
Old 01-12-2015, 12:29 PM   #15
SCOTI
SCOTI's Avatar
Nate
Any torque specs for the bushing hardware?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-12-2015, 02:30 PM   #16
PBFAB.COM
PBFAB.COM's Avatar
Zero lash (seat the crush tube) and 1/4 turn.
Nate
Phone: 480-297-2621
Porterbuilt
Accuair
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Old 01-12-2015, 04:17 PM   #17
SCOTI
SCOTI's Avatar
Nate
Thank you sir! That's about what I did.
They still moved (pivoted) freely so I thought I would verify just in case.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 01-12-2015, 04:42 PM   #18
Ronzo
Ronzo's Avatar
That's epic customer service.
I'll be saving my Canadian money to get some of their products.
Ronzo is offline   Reply With Quote
