Old 02-28-2010, 11:44 PM   #1
crushermechanic
crushermechanic's Avatar
vortec head ?
i have a set of 906 vortec heads i am going to run on my 350. my cam lift specs are .479I .465e. will these heads work with new springs or will they have to be machined?
crushermechanic is offline   Reply With Quote
Old 03-01-2010, 12:41 AM   #2
shortbed70
shortbed70's Avatar
Re: vortec head ?
I think you can run comps beehive spring with no problems but I would take them to a shop and have them check before you put it togather and tear something up.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-01-2010, 01:14 AM   #3
Captainfab
60-66 Nut
Re: vortec head ?
I have run a similar cam in an engine with Vortec heads that were upgraded to the 981 springs with no retainer to guide/seal issues. However you should always check your particular combination for proper clearances.
Old 03-02-2010, 01:45 AM   #4
G-Ring
G-Ring's Avatar
Re: vortec head ?
Are you running flat tappet or roller cam? It may make a difference, factory vortec springs are light pressure for rollers.
79' Big Ten
70' 1 ton 4x4 LB "Mean Green"
70' SWB "Major Project"
69' El Camino "t-boned by Camry"
G-Ring is offline   Reply With Quote
Old 03-02-2010, 08:50 AM   #5
crushermechanic
Re: vortec head ?
i am running a flat tappet cam. i am not running the stock springs. i bought the springs recomended for this cam.
Old 03-02-2010, 09:40 AM   #6
nomrlz
nomrlz's Avatar
Re: vortec head ?
that was a very wise decision. the right spring can make all the difference in a cams performance
nomrlz is offline   Reply With Quote
