Old 04-02-2011, 02:19 AM   #1
steve'62
steve'62's Avatar
where to plug gas tank wire??
When I purchased my truck the gas guage was not working, nor was there a wire going to the fuse block. I replaced the sending unit and got a new wire but dont know the correct plg in on the fuse block...please help. its a 62 if that matters!
steve'62 is offline   Reply With Quote
Old 04-02-2011, 10:28 AM   #2
steve'62
steve'62's Avatar
Re: where to plug gas tank wire??
c'mon just show me where to plug the wire!!
Old 04-02-2011, 10:38 AM   #3
Clyde65
Clyde65's Avatar
do you have a factory assembly manual? if not i would suggest it. im not being an a$$ really, it comes in handy alot for me. they have wiring diagrams and are usually under $20.
if i had the diagram you needed, i would post it for though.
iirc, the wire from the guage goes to the sending unit, the other wire on the sending unit is ground
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 04-02-2011, 10:54 AM   #4
steve'62
steve'62's Avatar
Hmmm, so it doesnt run through the fuse box? I have a wiring diagram, its not really helping me out though. I thought my wire from the sending unit goes to the fuse box?? could be wrong though.
Old 04-02-2011, 11:05 AM   #5
Clyde65
Clyde65's Avatar
from the guages fuse to the guage for power, then to the sending unit, the to ground. the difference in the resistance in the sending unit makes the guage move. I can only find this on the net.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-02-2011, 11:12 AM   #6
steve'62
steve'62's Avatar
does it matter where i plug the wire from the sending unit to the fuse?, thats what i need to know! thanks for replying clyde
Old 04-02-2011, 11:17 AM   #7
Clyde65
Clyde65's Avatar
Hey no problem, I cant get to my assembly manual, I am at work.
the "hot" wire should already be at your guages, assuming you have stock harness. the wire that goes to your sending unit, I think is brown, but I could be wrong there.
Look at the 2nd page, hot wire is the pink to the guage, tan one goes to sender.
The diags will help you brother.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-02-2011, 12:50 PM   #8
steve'62
steve'62's Avatar
yes you are correct it is brown, and i also see the pink one, but i still dont know where to plug the tan one in? everything is connected except the tan plug
Old 04-02-2011, 12:53 PM   #9
Clyde65
Clyde65's Avatar
tan plug where? have you looked at the wiring diagrams I attached> page two has the fuel sending unit and then you follow it to the guage.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-02-2011, 01:03 PM   #10
steve'62
steve'62's Avatar
Ok, so i dont need to run the tan wire through the fuse box, pink at guage, and tan can go directly to the sending unit from the gauge, thank for attaching those
Old 04-02-2011, 02:05 PM   #11
Clyde65
Clyde65's Avatar
yes, that is how it's done. print the wiring diagrams, you will need them.
Clyde65
Rebuild of Clyde
support our troops!
Old 04-02-2011, 03:51 PM   #12
steve'62
steve'62's Avatar
Thanks again for all your help!
Old 04-02-2011, 05:34 PM   #13
Clyde65
Clyde65's Avatar
your very welcome sir!
Clyde65
Rebuild of Clyde
support our troops!
Old 04-03-2011, 01:57 AM   #14
stsalvage
Scrapper 1
stsalvage's Avatar
Smile Re: where to plug gas tank wire??
hay whats up well on your fuse panel it will say gas plug it in there This is a picture of a 1964--66 fuse cluster and i had 3 other people ask me about this wire so here are some pictures
stsalvage is offline   Reply With Quote
Old 04-06-2011, 09:22 PM   #15
Ed 72 Sierra Grande
Ed 72 Sierra Grande's Avatar
Assuming you have stock gauges still in tact, The tan wire is what you want to connect to your sender. The other wire on your sender is ground. (On your frame). The pink wire if stock should be intact.
Seal your splices to prevent corrosion or you will be chasing a problem again in 6 months.
I use brush on electrical tape. Works good on boats so should hold up on your sender splice.
Ed F
1972 Sierra Grande
White Top Medium Olive
402 bb / Camper
Stock, Loaded, Straight & Aged Nicely, No Tilt
Original Resto would be nice $
Ed 72 Sierra Grande is offline   Reply With Quote
Old 04-06-2011, 11:02 PM   #16
neto
neto's Avatar
Where do you get the brush on electrical tape?
neto is offline   Reply With Quote
Old 04-06-2011, 11:21 PM   #17
chopper john
chopper john's Avatar
the sending unit doesnt work with power, its a ground. you already have power to your guages. the guage has a power side and a neg. side . since you have power on the guage the ground side goes to the sending unit. that completes the cycle at the guage and converts to ohms.
chopper john is offline   Reply With Quote
Old 04-07-2011, 07:19 PM   #18
steve'62
steve'62's Avatar
Thanks for the pics stsalvage thats what i was looking for! My words are mostly worn off. Still havent got it working. Its jumping around, seems like it works then I move some wires and it stops. I think there is a short somewhere because after that I got a "zap" from the dash board. About to just buy a completely new harness/fuse box. The wiring in my truck is a disaster. Brittle as well, the last thing I need it for it to burn to the ground!!lol
Old 04-08-2011, 09:25 AM   #19
Clyde65
Clyde65's Avatar
Sounds like you have a new direction to pursue. May I suggest from someone who has done too many "cheap" harnesses, go with AAW, Classic Update series if your planning on adding anything like AC or something. they also have one that is just like factory.
Pay for the best one and only do it once. IMO.
http://www.americanautowire.com/
Clyde65
Rebuild of Clyde
support our troops!
Old 04-08-2011, 10:18 PM   #20
steve'62
steve'62's Avatar
Thanks for the advice I was wondering what a good brand is as I am seeing so many out there!
Old 04-26-2011, 02:00 AM   #21
Ed 72 Sierra Grande
West marine and Wally mart carries it also
Ed F
1972 Sierra Grande
402 bb / Camper
