Old 06-26-2011, 04:48 PM   #1
cjohnson6772
cjohnson6772's Avatar
Kick panel vent question
On a factory air truck the passenger kick panel vent is operated via a vacuum canister. I have replaced my factory a/c unit with an aftermarket unit that no longer uses the vent for fresh air. I would like to convert the passenger vent to a pull handle arrangement like the driver side. I know trucks without factory air had pull handles on the passenger side too. My question is would I have to change the whole vent? Or can I remove the vacuum canister and spring and replace with a non-a/c style pull handle? Pics of non-a/c setups are appreciated as well. Just trying to figure out what all I need to change.
cjohnson6772 is offline   Reply With Quote
Old 06-26-2011, 04:51 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Kick panel vent question
Sounds like a good plan, to me. If your aftermarket AC unit doesn't need fresh air in the same way that the OEM AC needed/used it, I don't know of any reason why you shouldn't use a Non-AC vent door. I've seen them in the Brother's catalogs.
Member Nr. 2770
Old 06-26-2011, 04:59 PM   #3
BMERDOC
BMERDOC's Avatar
Looks like if the door is the same all you need is the pull rod assembly. My 67 non a/c.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 06-26-2011, 05:02 PM   #4
cjohnson6772
Sweet. That is what I was hoping. I don't wanna have to actually replace the door/seal. Just curious: is that the driver or passenger side? Are they the same?
Old 06-26-2011, 05:09 PM   #5
BMERDOC
BMERDOC's Avatar
I took a pic of the dr's side before I thought about it but looked over to the pass side. They are the same but side specific.
Nick Carter
Old 06-26-2011, 05:20 PM   #6
cjohnson6772
Perfect! Thanks for taking time to snap the pic!
Old 06-26-2011, 05:28 PM   #7
BMERDOC
BMERDOC's Avatar
Effortless on my part! Its Sunday and I've finished my chores. Watchin tv and clickin refresh every 15 minutes to see whats new!
Nick Carter
Old 06-26-2011, 05:32 PM   #8
cjohnson6772
Lol same here.
