Old 05-07-2013, 02:04 PM   #1
kikkegek
kikkegek's Avatar
custom center console - how to raise the 4WD selector
he guys,
I want to build a custom center console for our Suburban.
But that would "hide" the 2-4WD-HI-LO selector if I dont raise it.
I looked under the car, but dont immediately had a brught idea how to change the linkage to make sure it still works afterwards.
Anybody done this yet?
kikkegek is offline   Reply With Quote
Old 05-07-2013, 06:26 PM   #2
king-918
king-918's Avatar
Re: custom center console - how to raise the 4WD selector
Extend the shaft itself
<----Christopher
Oh yeah I'm really a Toyota guy, but had some stuff sitting around.
Oklahoma
king-918 is offline   Reply With Quote
Old 05-09-2013, 11:45 AM   #3
kikkegek
kikkegek's Avatar
thanks, but that will take up a lot of room in the console, since the extended arm will make the shifter travel more.
I might just hide it and make a door so I can access it whenever I need it. Dont use it that much
Old 05-09-2013, 12:35 PM   #4
1981Stepside
1981Stepside's Avatar
You could always make another shaft with a pivot in the console and attach it with a wrist pin to the original shaft. It'll reverse the shift pattern but will have the same throw.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 05-09-2013, 12:58 PM   #5
kikkegek
kikkegek's Avatar
thanks man!
I was more looking for either proven custom solutions or some after market stuff.
was hoping to find other 4WD drivers that made a center console
Old 05-09-2013, 02:26 PM   #6
83GMCK2500
You could adapt the GMT-400 style shifter that bolts to the driver's side of the hump to your truck. A friend of mine put a square body transfer case in his GMT-400 for his SAS and built a z-bar type pivot that bolted across the trans/tcase adapter which allowed him to shift the tcase from the other side of the tunnel.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 05-09-2013, 04:38 PM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
keep it stock height or shorter?
make a "extra" shifter handle that slides down over old one?
open cover ,slide shifter on,shift ,remove,close cover
or have the shifter nut size welded on top a six inch+ tube, slide another tube over that cut to lenght...
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-09-2013, 11:42 PM   #8
andrewmp6
Or a ford style shifter which is on the side of the trans hump.Either way you will be stuck making your own shifter linkage.
Old 05-10-2013, 12:15 AM   #9
MalibuSSwagon
You could make it a short throw shifter, its the same concept as a Honda Civic shifter. Add length between the pivot and the spot where the t-case linkage bolts on, making the throw shorter. So now when you make the top of the handle longer, the throw is the same as stock.
MalibuSSwagon is offline   Reply With Quote
Old 05-10-2013, 12:54 AM   #10
83GMCK2500
More on my earlier post...pictures.
Here is an NV-4500 and NP-241 that is going into a 1988 GMC K1500, the passenger side drop NP-241 is from a square body. Notice the linkage for the transfer case.
It is built for this style shifter.
Devin
New Daily, the '96
