02-09-2014, 08:27 PM | #1 |
Another gas gauge thread...
I have seen a few, but none doing exactly what mine is. Basically the needle points at full or a little beyond and then when the key is turned on it moves to 3 o'clock (way past full). I looked under the truck since many threads say to check the ground at the tank. There was a purple wire grounded to the inside of the frame just under and to the front of the tank. I'm not sure if that is for the sending unit, but I went ahead and removed it, cleaned it, and reinstalled it with no luck. I also cleaned the one that goes to the filler neck - just because. Any advice before I pull the cluster????
02-10-2014, 05:20 PM | #2 |
Re: Another gas gauge thread...
if your gauge is going to 3:00, sender wire is crimped, broke, etc. trace your sender wire from the switching valve to the firewall. usually they get damaged in that area
02-10-2014, 08:25 PM | #3 |
Also if its a dual tank check the passenger side wire also might be a brake there
San Antonio, TEXAS -Frog -I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it. |
02-10-2014, 08:55 PM | #4 |
It only has a single tank. Any idea what color wire it is - I know "get a damn manual". If you know off hand I would appreciate it.
02-10-2014, 09:07 PM | #5 |
02-10-2014, 09:16 PM | #6 |
02-11-2014, 06:24 PM | #7 | |
78K & 79C Jimmys
(my 78 is tan and tubes) if the cluster has been changed sometimes the wire needs to move spots(my 78 did) with sender wire off, goes over full,grounded goes to E
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
02-11-2014, 06:50 PM | #8 | |
Moderator
The ground has come off the frame or sender ring... The sender to gauge wire has been damaged... Manuals? Look down.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
02-11-2014, 08:04 PM | #9 |
Thanks man!!! Your wiring diagram link confirms I am looking for a pink wire for signal and the purple wire I found is the ground.
02-12-2014, 12:06 AM | #10 |
Sorry to hijack your thread but I'm having a similar problem.
Would the same wire be the same color on an 87 454 TBI suburban?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824 |
02-12-2014, 03:09 AM | #11 |
This sounds like it could be what's wrong with mine. Gotta check mine out now.
1974 C10 swb 350 1977 3/4 ton Silverado 454 1999 2 door 2wd Tahoe |
02-12-2014, 03:22 PM | #12 |
Found a brown sure coming from firewall about 10 inches long and it has a black plastic plug on the end that's not connected to anything. Could that be for the gas tank?
02-12-2014, 04:20 PM | #13 |
78K & 79C Jimmys
Yes, look for another " mate" to fit , try the tank frame rail area
02-12-2014, 04:59 PM | #14 |
the easiest way to check if it's your sending wire, cut the wire as close as you can to the switching valve, then cut the wire at the firewall & tie in a new piece of wire. when i put my truck together a few yrs ago, i heat shrunk the wires, covered them in insulation with zip ties, then bundled them & zip tied convoluted tubing to them, then clamped them to the frame. good for longevity, lousy for finding any breaks, thats why i did mine that way.
just stuffed the new wire in the tubing. last yr i got ambitious & fished out the old wire, sure enough it had got sliced by a clamp |
02-13-2014, 03:41 AM | #15 |
I meant a brown wire. I will post a pic of it later in the day. I sure hope that's all it is that's wrong is it's not connected
02-13-2014, 11:22 AM | #16 |
Here is the wire I am talking about with the plastic clip type connector thing at the end. So this is defintely the sending unit wire coming from the firewall? It lines up with the instrument cluster. It may not look like its tan in color in the pic but it is. My truck is a 1974 c10. So all sending units have this connector?
02-13-2014, 01:40 PM | #17 |
I got a 74 K10 with a 350 and turbo 400 and my gas gauge moves all over the place, I just try to keep it topped off.
02-13-2014, 01:52 PM | #18 | |
78K & 79C Jimmys
with an add on piece to the tank
02-13-2014, 03:26 PM | #19 |
I traced the wire from the tank along the frame rail and as it gets up by the passenger side spring it is pinched between there and a bracket. So I had to go up top above engine and look down for it and nothing's there. Previous owner must have done it without realizing it. Guess I gotta cut it then add to it and see what happens
02-13-2014, 06:58 PM | #20 |
Moderator
The 1974 GM wiring diagrams will show wire color, wire gauge, and which cavity in the Packard 56 bulkhead plug is for the fuel gauge sender wire. The original plug on the frame rail is a molded rubber piece.
I'm not sure what that Packard 56 plug in your picture goes to.
