Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 04-01-2015, 09:05 AM   #1
tanman722001
tanman722001's Avatar
Fast Idle
Hi guys, On my wife 93 S10 blazer. It has the vortex 4.3 in it. What would cause it in the last couple weeks idle higher then normal? It idle high enough she can go 40 on flat ground without touching anything. So I need to get it fix. Thanks Tony
1991 GMC K2500 4X4 350/auto
1991 Chevy S10 ext cab.
1990 Chevy S10
1993 Chevy S10 Blazer 4dr 4.3 Vortex/Auto
tanman722001 is offline   Reply With Quote
Old 04-02-2015, 08:18 AM   #2
tanman722001
Re: Fast Idle
Any ideas
1990 Chevy S10
Old 04-03-2015, 08:29 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
Re: Fast Idle
What is the TPS voltage? How many counts of the IAC?
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 04-03-2015, 09:54 PM   #4
Carmen Black
Carmen Black's Avatar
Re: Fast Idle
I had something similar to this. You had to stand on the brake just to hold it at a stop sign. I believe replacing the modulator and knock sensor fixed it. But this was 20 years ago, so I could be fuzzy on that.
Carmen Black Build
1971 SWB - Base Model
Carmen Black is offline   Reply With Quote
Old 04-04-2015, 11:51 PM   #5
tanman722001
Re: Fast Idle
68C15 I have no idea on voltage. I changed the IAC and TPS. It helped very little. When you use a jumper wire on the plug under dash with the key on it throws 35. Which in my book say its the IAC right? Im lost I don't know what else to do any ideas??
1990 Chevy S10
Old 04-05-2015, 12:10 AM   #6
68c10airstream
68c10airstream's Avatar
Re: Fast Idle
Under the assumption it's a tbi 4.3, lift up the throttle body by removing the 3 bolts and replace the tbi base gasket. It's leaking air in under the base. If you are handy you can still leave the fuel lines and everything else attached. I'm handy because i'm not handsome. That's what i tell my wife! Ever seen a good looking plumber? Mechanic? Maybe on tv, but not in real life.
68c10airstream is offline   Reply With Quote
Old 04-05-2015, 01:25 PM   #7
68c10airstream
Re: Fast Idle
If this is not a tbi set up, get someone to look at iac counts at idle. Look at target idle speed. As an example; target idle set point is displayed 750 rpm, iac counts 0, actual idle is 825 rpm's you most likely have a vacuum leak bringing unwanted additional air into the engine. Just some idle facts are this; iac counts are a rough means of adjusting idle and fine adjustments are done by advancing or retarding timing to get to the target idle speed. Don't throw your old iac motor away as i can show you how to make the best iac tester by removing the nose and soldering in led's and resistors to be able to plug in and see if the ecm circuitry is complete and the iac drivers are working properly by looking at the led light flashes and color changes. Absolutely no guessing with that tool installed.
Old 04-07-2015, 07:39 AM   #8
tanman722001
Re: Fast Idle
It is not a TBI.I think I either found out what's wrong or another problem. The upper intake gasket it leaking. Would that cause the problem? Thanks
1990 Chevy S10
Old 04-07-2015, 11:35 PM   #9
68c10airstream
Re: Fast Idle
Absolutely a vacuum leak would cause this issue. Is this the plastic upper half design? Spray carb cleaner near the suspect area and see if idle quality/rpm changes to verify. You can also use the info in post #7 as a guide. GOOD LUCK
Old 04-08-2015, 12:06 PM   #10
tanman722001
Re: Fast Idle
that's how I found it with carb cleaner. Alum upper half
1990 Chevy S10
Old 04-10-2015, 08:56 AM   #11
tanman722001
Re: Fast Idle
All fixed. Runs good know. I changed the gasket.
1990 Chevy S10
