Old 09-03-2014, 07:16 PM   #1
Jbarrkn493
Jbarrkn493's Avatar
Think i might have a problem with my heads. Help please!
Im replacing most of the top end and when i pulled off the intake manifold i saw several chunks missing off the driver side head, passenger side looks to be fine.. Is this a major problem or am i overreacting?
Jbarrkn493 is offline   Reply With Quote
Old 09-03-2014, 07:17 PM   #2
Jbarrkn493
Jbarrkn493's Avatar
Re: Think i might have a problem with my heads. Help please!
Heres a picture of the whole engine
Old 09-03-2014, 07:21 PM   #3
68gmsee
Active Member
68gmsee's Avatar
Looks pretty rusted and pitted. Look for some better heads to rebuild. You can usually pick them up fairly cheap at a salvage yard. Or go to a machine rebuilding place. They usually have heads already rebuilt for sale.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 09-03-2014, 07:25 PM   #4
franken
I wouldn't worry about the little corner right above the pushrod in the pic.
Old 09-03-2014, 07:29 PM   #5
Jbarrkn493
Jbarrkn493's Avatar
That's the placement of all the damage on that head, only on the inside near the oil valley, not on any of the ports.. Is this a problem I can deal with at a later date or would this some how mess up my engine further?
Old 09-03-2014, 07:44 PM   #6
casper71
looks to be the casting from the factory. That is nothing to be concerned about
1972 3/4 ton 402/400
1971 k20 lwb 8.1.4l80.np205 w/37" tires and 6"lift
casper71 is offline   Reply With Quote
Old 09-04-2014, 12:57 AM   #7
Captainfab
60-66 Nut
That little bit of casting chipped away isn't going to cause any problem at all. It isn't where it is going to cause a sealing issue.
Old 09-04-2014, 01:06 AM   #8
Jbarrkn493
Jbarrkn493's Avatar
Thanks for all the input, I'll sleep happy knowing I don't have to replace my heads (just yet)
Old 09-04-2014, 09:56 AM   #9
68gmsee
Active Member
68gmsee's Avatar
In your first post, you mentioned you were replacing most of the top end. My assumption is that you were also going to rebuild or replace the heads. The chip itself is not the reason I recommended the head replacement but for the pitted look of the head surface. It may be that it's surface oil/grime but in my computer it looks like surface rust pits. A good machine shop will be able to let you know.
06 Trailblazer
Old 09-04-2014, 10:06 AM   #10
DBD
Originally Posted by captainfab View Post
that little bit of casting chipped away isn't going to cause any problem at all. It isn't where it is going to cause a sealing issue.
+1
DBD is offline   Reply With Quote
Old 09-04-2014, 12:12 PM   #11
truckdude239
truckdude239's Avatar
just use a little rtv around the coolant ports and a 1/4 " bead at the ends
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-04-2014, 12:18 PM   #12
Jbarrkn493
Jbarrkn493's Avatar
No, I want to replace them with some aluminum heads, I just don't have the money right now for that, I misspoke when I said I was replacing most of the top end
Old 09-04-2014, 02:04 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
How many miles does this engine have on it? If you bolt on new or even reconditioned heads with new seals and a 3A valve job... you'll suck oil past the rings making it an oil burner, and probably foul plugs.
A top end rebuild will affect your bottom end. Unless the engine has less than say, 100K on it. And I've see where even that can still cause some problems with burning oil.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-04-2014, 02:16 PM   #14
Jbarrkn493
Jbarrkn493's Avatar
Gary
I have no idea the milage on the motor, it's 350 sbc from a '75 chevy, dunno what model car, the engine suffix and partial vin on the engine have been inconclusive. Im fairly sure the motor has well over 100k on it, if I'm replacing from the intake manifold up I won't have a problem with it burning oil, will I? And good advice I'll take into account when I do get around to replacing the heads
Old 09-04-2014, 02:21 PM   #15
Jbarrkn493
Jbarrkn493's Avatar
Gary
Heres a picture of the engine codes, maybe you could tell me what car this engine was in??.. Also it looks to me like the partial vin has been tampered with
Old 09-04-2014, 02:40 PM   #16
GASoline71
GASoline71's Avatar
1975... and with the amount of oil and crud on it... then it's probably got a lot of miles on it.
TYZ = 1975 350, conv.cab, L LS9, 165, 4, C-10 to 2500
Gary
Old 09-04-2014, 03:00 PM   #17
Jbarrkn493
Jbarrkn493's Avatar
Thanks Gary!
chevy, damage, engine, head, rebuild
