09-27-2003, 05:47 PM | #1 |
Painting my top
Whats up guys,
I want to paint my top but I'm not sure how to. Do I just primer than paint or what?
72 GMC JIMMY 67 GTO Post 99 Audi A6 (Wifes car) |
09-28-2003, 05:37 AM | #2 |
Gel-Coat
You could paint it like sheet metal, but you might get better results going to a boat shop and getting (white?) gel coat. It's a kind of epoxy stuff for fiberglas. You may have to do a light sanding so the paint takes. I looked into it but havn't done it myself so I'm only the armchair expert here. Maybe someone with actual hands-on can jump in here.
09-28-2003, 03:38 PM | #3 |
I work with polyester gelcoat quite abit in fiberglass boat repairs . If you have never worked with gelcoat I would recommend you go with an epoxy primer and just paint it.
You can spray gelcoat on if its prepped right but you need to put wax additives in and thin with styrene and add 2% hardner and I also use a speed patch additive up to 30% after all that use small batches so that it doesn"t kick off in your gun, I use a cheap gravity feed gun from harbor freight just clean it out good with acetone. Hope this helped My 2cents kman
New 89 chevy 1500 driver 72K20 rust bucket project stripped down to the frame engine rebuild started 71 Blazer - another procect |
09-29-2003, 03:58 PM | #4 |
Thanks alot guys thats exactly what I wanted to know!!
