09-01-2015, 07:07 AM | #1 |
Oil sending unit w/ HEI
How are you guys running the oil sending unit with and HEI distibuter? I have a 1979 C10.
I assume just get a small pipe out of the block and add a 45 degree fitting on it and just bend it out of the way your thoughts
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart My build 2008-2016. http://m.imgur.com/a/bURrE |
09-01-2015, 07:29 AM | #2 |
Senior Car Nut
Re: Oil sending unit w/ HEI
that's exactly what I did on my car with aftermarket gauges. the sender was too big to fit even with small cap distributor
Larry |
09-01-2015, 08:03 AM | #3 |
I had no problem using the factory stock sender and tubing on a few 350's that I had
09-01-2015, 07:55 PM | #4 |
I assume this is an electric and not mechanical gauge? With the huge sending unit You can use a pipe and a 45 or 90 to easily clear everything. If im not mistaken the sending unit by itself will clear.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
09-01-2015, 08:33 PM | #5 |
Installed with a 45 degree bend. Pretty ticked. As soon as I was done and cleaning tools up I found the pipe and 45 angle sitting on the intake I bought some time ago. Oh well. Got to go to a cool friendly hardware store today to get what I already had. So at least that. Was fun?
09-01-2015, 10:44 PM | #6 | |
09-04-2015, 02:10 PM | #7 |
Dino burner
A number of years ago, I was trying to get a project running and on the road and I did not have a 45-degree elbow. I did, however, have a flexible hose designed for grease guns which I used with a standard Tee so that I could run both the indicator light and aftermarket gauge.
