Old 09-24-2003, 03:13 PM   #1
72c10step
WHYBYNU when old will do?
72c10step's Avatar
Front and Rear Sway Bar Questions
I have a few questions about front sway bars for our trucks and the rear IROC sway bars.
First, if I grab a front sway bar off a 75 Chevy for example, would I need to buy new bushings for a 75, or a 72, or are they both the same? Also, can I get all new brackets, including the ones that bolt to the frame brand new, or can I reuse the old ones if they aren't too rusty, and if I can get them new, about how much and where?
For the rear IROC bar, what else would I need to remove off the Camaro to put it onto my truck, and what will I need to buy new for it?
Sorry for all the questions, I just don't want to leave any parts behind that might be hard to get later when I find these in the salvage yards.
Thanks,
Jay
-72 Chevy C10 Stepside
-2002 Chevy Silverado 2500HD 4x4
-1984 Jeep CJ7
-1995 Polaris XCR600 Custom
-2003 Honda 300ex
72c10step is offline   Reply With Quote
Old 09-24-2003, 03:43 PM   #2
CPNE
Resident Curmudgeon
CPNE's Avatar
Re: front swaybar.
The bushings are sold based on bar diameter, not year of application. So if you tell them 72 or 75 or 80, etc they will still want to know diameter. You can buy these at any parts store
The clamps that hold the bushings will proably be junk but you can get them thru a chevy dealer. They are the same for 73-up as they are for 67-72.
The bracket that is on the frame is a question mark to me. thought you could not get them new, but I've since read you could. So I'm not sure. I'd grab it them with the swaybar if possible. They are riveted on so bring a smoke wrench with you.
I believe all years up thru 87 are interchangeable. I have a sway bar but no brackets. If you can find the frame brackets and want to swing buy, you can have the bar cheap.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 09-24-2003, 04:14 PM   #3
72c10step
72c10step's Avatar
CPNE,
Thanks, I'll be heading to a yard in Belmont over the weekend, I'll see what I can find there, hopefully I'll get lucky. If not, I'll be looking in the yards in Michigan while I'm at college for the next three months, but my friend is also looking for the same, so if I don't find anything, I'll tell him to look while I'm gone. What size bar do you have?
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-24-2003, 04:45 PM   #4
smokekiki
Mike
smokekiki's Avatar
Check this link http://www.low69cst.freeservers.com/CamaroBar.htm
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 09-24-2003, 09:10 PM   #5
neonlarry
neonlarry's Avatar
Also check out this threadfor a discussion on rear bar.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 09-25-2003, 02:38 PM   #6
72c10step
72c10step's Avatar
CPNE-
It looks like Early Classic does carry the frame mount brackets. They have them for stock and lowered trucks for $19.00 a pair. Sounds better to me then trying to tear the old ones off, sandblast and paint them, and then put them back on. Thanks for the help everyone.
EDIT-
Low69CST's site shows the Camaro bar brackets welded in, but I noticed someone said they made it a bolt in. Can someone fill me in on how that was done, and how much harder it would be? Also, if the truck was stock, then lowered at some later point, would that screw up the points where the brackets mount to the frame, or could I just get shorter end links?
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-25-2003, 02:40 PM   #7
CPNE
Resident Curmudgeon
CPNE's Avatar
Originally posted by 72c10step
CPNE,
I think it's a 3/4 ton version as that is what most of the trucks I parted that had them were.
Old 09-25-2003, 02:43 PM   #8
72c10step
72c10step's Avatar
The 3/4 tons came with either 1 1/8" or 1 1/4" right?
-1984 Jeep CJ7
-2003 Honda 300ex
Old 09-25-2003, 04:06 PM   #9
fatfords
fatfords's Avatar
The brackets that are riveted to the frame are available at your local GM dealer, part number 6271375. It was just under $20 without tax. If you're at a yard, grab an extra set (4) bushing clamp mounting bolts when you get the bar, as they should be grade 8, suitable for suspension work.
Good Luck
'56 F-100 (w/all GM stuff)
Lookin' for another parts chaser!
'05 GMC crew cab
fatfords is offline   Reply With Quote
Old 09-25-2003, 04:52 PM   #10
neonlarry
neonlarry's Avatar
The Rear bars are bolt-in on the cameros, but their axles are smaller diameter. Just get some larger(3") heavy duty u-bolts and saddles and you can bolt to truck axle. As for lowering it would just be the end links and all you would have to do is cut down the spacer.
Old 09-25-2003, 08:21 PM   #11
Dusti
Not Dusti,just Bob
Dusti's Avatar
That depends on what year truck the swabar came out of.
I have 2 sway bars that are 1 1/16 and 0ne that is 1 3/16.
Bob W
72 cheyenne super 1/2ton
89 camaro
Dusti is offline   Reply With Quote
