Old 03-22-2016, 08:23 PM   #1
PIG-TECH
PIG-TECH's Avatar
seatbelt install?
i am wanting to install seat belts in 72' C20. it has no belts or mounts.
so i not sure the proper way to install them. I have not bought them yet either.
thanks for feed back
PIG-TECH is offline   Reply With Quote
Old 03-22-2016, 09:03 PM   #2
flashed
Re: seatbelt install?
I put Morrisclassics in mine ,3 point .You can find vendors on this site ,I bought mine through Matts Classic Bowtie .
flashed is offline   Reply With Quote
Old 03-23-2016, 12:14 PM   #3
snipescastle2
snipescastle2's Avatar
Talking Re: seatbelt install?
I have a '71 and I'm pretty sure they came with belts for sure after '71.
There should be anchor bolts or at least the cage nuts/weld nuts in the floor sheet metal behind the seat directly beneath the fuel tank mount.
Two in the center (small bolts) and two large Bolts,one on either end of the seat.probably a 1/2" bolt,not sure what size the others are,maybe 3/8"?
HTH,
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 03-23-2016, 01:12 PM   #4
ettsn
ettsn's Avatar
You should probably also have plugs in the B-pillars that you can pop out to mount the shoulder anchors. If you're adding belts, it's crazy not to strongly consider three point belts. It's really the only truly safe choice in our trucks, and it was a factory option, so the purists don'r argue too much.
ettsn is offline   Reply With Quote
