Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 01-30-2016, 08:56 PM   #1
coopdog
coopdog's Avatar
Fitech swap on my 1972 K20
I have not done much to my K20 in a while, I had been researching fuel injection for a while and after my brother put a 6.0 LS in his 54 International, I knew it was time to bite the bullet and modernize my old carbureted small block.
.................._____
__________//___{\____
/__---____//____/__---/
.....(O). ..................(O).
BUILD THREAD K20 http://67-72chevytrucks.com/vboard/s...d.php?t=651601 pages 2-4
coopdog is offline   Reply With Quote
Old 01-30-2016, 08:59 PM   #2
coopdog
coopdog's Avatar
Re: Fitech swap on my 1972 K20
I figured I would show some pics of the current set up before the swap
Old 01-30-2016, 09:03 PM   #3
coopdog
coopdog's Avatar
Currently I'm running a 750 double pump mechanical secoundary, dart aluminum heads , headers , flat top pistons , and a 274 comp cam
Old 01-30-2016, 09:05 PM   #4
coopdog
coopdog's Avatar
Some pics of the new system I went with the tumbled finish in stead of the black, it's rated for up to 600 hp
Old 01-30-2016, 09:08 PM   #5
coopdog
coopdog's Avatar
More pics
Old 01-30-2016, 09:13 PM   #6
coopdog
coopdog's Avatar
This is the most up to date status, I'm currently waiting on the fuel command center to arrive from summit
Old 01-31-2016, 01:52 AM   #7
swamp rat
swamp rat's Avatar
Subscribed! I have been thinking about how nice this would be myself.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 01-31-2016, 08:08 PM   #8
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Also going this route.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 01-31-2016, 08:13 PM   #9
jjzepplin
jjzepplin's Avatar
I'm in!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 02-06-2016, 12:50 AM   #10
LostMy65
LostMy65's Avatar
How's it going?
Old 02-06-2016, 09:34 AM   #11
coopdog
coopdog's Avatar
Sorry it's been a while fellas , I got a little busy with my school work, but here's some more pics . O2 sensor plate Tiged
Old 02-06-2016, 09:37 AM   #12
coopdog
coopdog's Avatar
Inlet fuel filter
Old 02-06-2016, 09:41 AM   #13
coopdog
coopdog's Avatar
Fuel command center
Old 02-06-2016, 09:49 AM   #14
coopdog
coopdog's Avatar
Hopefully today after wireing we will fire the old girl up
Old 02-06-2016, 01:39 PM   #15
coopdog
coopdog's Avatar
I just got it going and took it for a ride , the thing runs like a raped ape
Old 02-06-2016, 01:50 PM   #16
coopdog
coopdog's Avatar
It's a self learning system, the more it runs the better it runs !
Old 02-06-2016, 04:53 PM   #17
LostMy65
LostMy65's Avatar
Cool.
Is your gas tank in the cab?
If so, where'd you run your vent line from the command center?
Old 02-10-2016, 12:49 PM   #18
steelhorse
steelhorse's Avatar
Have you noticed any better mileage?
steelhorse is offline   Reply With Quote
Old 02-12-2016, 09:32 AM   #19
coopdog
coopdog's Avatar
I have not gone for a true road trip yet because of all the snow and salt we just got, but when the weather gets better I will let u know
Old 02-12-2016, 11:21 AM   #20
CUSTOM/10
CUSTOM/10's Avatar
Hmmmmm......
I just looked up that Fuel Command Center and that is a slick set-up. You leave your exsisting low PSI pump in place and feed the FCC from it. It's a sump with a high PSI EFI pump inside, and you feed the feul injection with that. Nice & easy !!!! Thanks, now I have to spend more money !!!! "LOL"
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 02-12-2016, 05:53 PM   #21
coopdog
coopdog's Avatar
Well fellas I'm into this deep so I figured I would treat the old girl a new set of slanted top value covers
Old 02-12-2016, 05:56 PM   #22
coopdog
coopdog's Avatar
, sorry about the dirty engine bay , Weeks been busy and neglected to give the old girl her weekly cleaning
Old 02-12-2016, 05:59 PM   #23
coopdog
coopdog's Avatar
Old 02-12-2016, 06:08 PM   #24
y5mgisi
Second Chance Program
y5mgisi's Avatar
Is your fitech setup still running good? Any adjustments that you have had to make?
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 02-12-2016, 06:51 PM   #25
coopdog
coopdog's Avatar
Yes yes , the system is running swell, I am very pleased with the product, still to this day I have rarely seen any one not be happy with the system
