Old 10-24-2016, 04:11 PM   #1
Jsoderbe
C6 ls2?
Hi,
I found a reasonably priced Corvette C6 engine I am considering for my 1959 Fleetside. I like the thought of a Corvette powered truck....
How have you resolved the rear mounted trans? Ia there a conversion kit to get the automatic trans mounted on the engine? Or do you go with the GTO combo?
Any other thoughs on the C6 LS2?
Regards,
Johan
Jsoderbe is offline   Reply With Quote
Old 10-24-2016, 04:23 PM   #2
davepl
davepl's Avatar
Re: C6 ls2?
You would need a conventional transmission like a 4L65E or 4L80E from a passenger car or 2WD truck. You can't make the rear-mount Corvette setup work in your truck (in any practical manner, at least).
There's no reason it needs to be an electronic transmission though, it could be a TH400 or TH350 as well. Heck, you could stick a powerglide behind it!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-25-2016, 03:38 PM   #3
Jsoderbe
Re: C6 ls2?
Thanks! So there is nothing different with the Corvette LS2? Meaning that a conventional gearbox bolt up without a conversion kit (to use engine without the torque box)?
Regards,
Johan
Old 10-25-2016, 04:01 PM   #4
Jsoderbe
Re: C6 ls2?
Regards,
Johan
Old 10-25-2016, 04:27 PM   #5
GMC-YA68
GMC-YA68's Avatar
Re: C6 ls2?
no, all the LS2s are the same. They are also everywhere so don't get too worked up because it's a "corvette" engine. It's also a SSR, TBSS, CTSV , GTO engine. And probably more.
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
