03-20-2017, 06:04 PM | #1 |
Temp gauge reading low
Just recently finished installing a rebuilt SBC 350 with aluminum heads. I re-wired the whole truck from front to back. I noticied that the temp gauge reads low. At first the temp gauge was pegged all the way to hot. I grounded the bottom terminal on the temp gauge and the gauge started working but it reads low. Could the temp sensor be bad or the temp gauge is bad? The temp gauge is brand new.
Thanks, Ramiro |
03-20-2017, 06:21 PM | #2 |
Re: Temp gauge reading low
I'm thinking the sensor and gauge are not compatable. Where is the sensor mounted and did it come with the temp gauge?
RUBBER DOWN AND HIT THE ROAD!!! 1940 Ford Dlx Coupe 1969 Mach1 |
03-20-2017, 06:24 PM | #3 |
Trace the wire from the sensor to the gauge.. make sure it's not grounding out somewhere
03-20-2017, 06:41 PM | #4 |
My56chevytruck the sensor is mounted on the drivers side on the block of the engine
03-20-2017, 06:45 PM | #5 |
03-20-2017, 06:49 PM | #6 |
The mounting is correct but is that sensor and gauge compatable? In other words, did they come together as a unit? Also, like others have said, check the grounding. Any possibility you have another gauge you can hook up to check against this one?? Nice engine.
03-20-2017, 08:13 PM | #7 |
What temp. thermostat do you have in the engine? Maybe it is reading correct, mine only sits a little to the right of that second line and never points straight up and down even on a hot day...
1971 C10 long bed, fleet side. 200R4 Auto, leaf spring rear. power steering. |
03-20-2017, 08:19 PM | #8 | |
03-20-2017, 08:24 PM | #9 |
RGT not sure what temp thermostat my son put in it. When it really warms up it gets to about the 2nd line. Also the sensor for his electric fan is 180 degrees and the fan turns off when it gets to 160 degrees.
03-20-2017, 08:30 PM | #10 |
I believe the original is Delco #G1852, so anything compatible with that should work.
Standard Motor Products TS6 or TS6T Airtext 1T1053 Do you have a part number for the sensor you used? I can check to see if it's compatible with the factory gauge just to make sure.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
03-20-2017, 08:37 PM | #11 |
Looks about right for these trucks. Mine ran about the same with a 180 thermostat. Back in the day most every one of these trucks I rode in ran about the same.
I put a 195 thermostat in mine and now it runs a little to the right of the first mark but I'm running a vortec engine which was meant to run a 195. I may just go back to the 180 for the summer though. |
03-20-2017, 09:53 PM | #12 |
Looks about right to me? Every one of these trucks I've owned will read right at that line or close to it. My LS has I believe a 180* stat (fans kick on at 200) and its verified by my OBD2 scanner right next to the gauge (just to the right of the line).
Check your T-stat. You may have a 165* or something and its reading correctly. Also, its not like these gauges provide much info. So long as you know what is normal - and can tell if its overheating, the gauge is doing its job IMO.
RIP EastSideLowLife '72 C20 SWB convert. 5 lug, LS1/4l60e |
03-21-2017, 01:44 AM | #13 |
I asked my son about the thermostat. He can't remember temp the thermostat is rated for. I'll assume everything is fine with his temp gauge where it reading. Than you all for your help.
Ramiro |
