Old 04-26-2017, 11:49 PM   #1
ScottH
ScottH's Avatar
Need info on how to remove tailgate band
I'm in the process of parting out a 89 K5 Blazer.
I would like to remove the tailgate band but not sure on how to go about it.
If anyone could shed some light on what needs to be done to remove the tailgate band I would appreciate it.
Scott
1963 C10 swb fleetside
1966 GMC G1000 Handi-bus (future project)
1955 Chevy 2 dr. wagon
ScottH is offline   Reply With Quote
Old 04-27-2017, 02:15 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Need info on how to remove tailgate band
There's been a couple of times I had to lower the tailgate and then wind the glass out (supported of course) to access something inside the 'gate shell. I've taken a couple of those bands off before but I don't recall if that was why. Take off the inner access panel and have a peek.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-27-2017, 09:33 AM   #3
ScottH
ScottH's Avatar
Thanks John, I'll pull the panel & take a look.
Old 04-27-2017, 09:50 AM   #4
Ski-me
Ski-me's Avatar
I take the cable off of the motor and then put my drill onto the end of the cable. Start slowly to be sure you are spinning the right way, and then you can run the window out (supporting it as mentioned above).
Once the glass is out of the way, I think the panel is attached with little nuts on the inner part of tailgate. The panel itself has threaded studs attached to it that go into the tailgate sheet metal, then bolted together with nuts.
If I'm lucky, it might be a 10MM socket.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 04-27-2017, 02:45 PM   #5
ScottH
ScottH's Avatar
Thanks guys, got it off.
