08-25-2017, 01:43 PM | #1 |
A question about gmc 1969
Hi
I have a question . Is it possible to convert Mechanical oil gauge To Electric oil pressure gauge ؟ I want the same gauge but electrician
MY Facebook ( saad_alhajri ) on Instagram
08-25-2017, 01:56 PM | #2 |
Proprietor of Dale's Corner
Re: A question about gmc 1969
Good question, I wish I had a answer for you.
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-25-2017, 06:16 PM | #3 |
Why do you want to convert? A VDO with a 10-2 Oclock might be close enough to stick your stock face on.
Good luck, post your solution if you hassle with it. j
White K20 |
08-25-2017, 06:35 PM | #4 |
Welcome sir. Conversion means the end of leaking oil inside the truck. Many of us suffer from this problem and want a solution
08-25-2017, 06:36 PM | #5 |
thank you my dear
08-25-2017, 06:44 PM | #6 | |
j
White K20 |
08-25-2017, 06:57 PM | #7 |
08-25-2017, 06:59 PM | #8 | |
08-25-2017, 07:08 PM | #9 | |
08-25-2017, 07:37 PM | #10 |
No, I figured just look at some of the parts suppliers for a repo. But if all you can find is universal compression kits then maybe cut off your original fittings and make your own lines.
White K20 |
08-25-2017, 07:43 PM | #11 | |
J
White K20 |
08-25-2017, 10:00 PM | #12 |
Mine has been working since 1970, no leaks yet but if it starts I'll replace the lines. Then I should be good for the next 50 or so years.
08-27-2017, 08:26 PM | #13 |
I don't know if this will work, but if you are looking for a possible solution, you might be able to use the later style oil pressure gauge from a truck or suburban. My 89 suburban (below) has one of the electric units, and that is a fairly common swap for the volt gauge.
If you grab the oil pressure sending unit off the newer engine, the block should be the same, so it would just be a matter of connecting up the wires and tapping into power off the rest of your gauges.
1972 GMC Jimmy Custom 4.8L (L20)/6L90E/NP205 1989 Chevy Suburban V2500 350/Turbo 400/4.11 gears 1996 Chevy Suburban K1500 350/4L60E |
08-28-2017, 12:51 AM | #14 | |
08-28-2017, 03:22 PM | #15 |
You might try a high-end gauge restorer like "Corvette Clocks by Roger" in Jackson TN. They could possibly convert it.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
08-28-2017, 04:01 PM | #16 |
The down side of going electric is the loss of accuracy. Every connection adds resistance and that affects the guages reading. It is the same issue with the factory water temp guages. That is unless you step up and go to a late model 5 volt PWM sensor and guage set up. But then you will need some sort of computing power.
That seems like a lot of effort to avoid a maybe leak that most likely could be avoided by cutting the factory steel tubing off at the old ferule and correctly installing a new ferule. But that is only my opinion.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
