Old 09-03-2017, 03:24 PM   #1
Backpayne
Which frame engine mounts needed?
The photo shows the engine mounts that are the same as on my Olds 455 block (previously in a Chevy).
Which engine frame mounts do I need for my '64 c10 to mate with the mounts pictured? I don't want to screw this part up as I'm sure I would order the wrong ones.
My '64 currently has a 250.
Thanks!
Backpayne is offline   Reply With Quote
Old 09-03-2017, 11:15 PM   #2
Captainfab
60-66 Nut
Re: Which frame engine mounts needed?
Those look like they are designed for the '73+ style of engine mounts. If so, you will need the frame brackets from a '73-'87 C20 or C30 and then the engine mounts that bolt to those.. You may need to trim the top flange of your frame back a little as well as possibly needing a 1/4" spacer between the top of the frame and the engine mount brackets.
Old 09-08-2017, 09:57 PM   #3
Backpayne
Thanks Captain! I bought some!
