06-22-2021, 07:46 PM | #1 |
72 C-20 Help
Evening Guys ive got a 72C-20 the PO took the clutch fan off and put this fan on with this spacer i want to put it back i have the correct fan if i put this clutch fan back on with the spacer will it be to far in the shroud ? Thanks Saddletramp
06-22-2021, 07:48 PM | #2 |
Re: 72 C-20 Help
The clutch takes the place of the spacer?
06-22-2021, 07:54 PM | #3 |
Re: 72 C-20 Help
Hi will that be the right distance into the Shroud with the clutch installed Thanks for the reply appreciate it Saddletramp
06-22-2021, 08:00 PM | #4 |
Who Changed This?
Re: 72 C-20 Help
It looks like the fan will be a little closer to the engine with the clutch on it, which looks to be OK in the picture. Are you sure that the clutch is good? Does it have oil leaking from the shaft, and is it hard to rotate as it is, off the truck? You will only be able to tell if the bearings have failed if you can wiggle it after installation, though.
06-22-2021, 08:39 PM | #5 |
Re: 72 C-20 Help
The clutch fan shaft doesn't turn good so going to a new one Thanks for the reply Saddletramp
