11-20-2017, 02:56 PM | #1 |
lower steering column bearing?
I just got a new lower column bearing, looking in the bearing i can see the balls. They appear to have a small amount of grease on them, but there seems like a lot of space for more grease. I am thinking i should pack this bearing like a wheel bearing. Is that correct?
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
11-20-2017, 08:36 PM | #2 |
One foot in front of the other
Re: lower steering column bearing?
I would if it were me.
11-22-2017, 12:08 PM | #3 |
I don't think a little extra grease can hurt.
I did mine with a bushing because I've seen a few of them over the years with chewed up shafts. Seems like some would ignore all the crunching and just keep on going. Mine had also failed causing some damage to the shaft but didn't matter because it got changed out for a 2 piece. |
11-22-2017, 12:33 PM | #4 |
ok , extra grease is a good idea. thanks
i can't find the page in shop manuals that describes setting the preload for the bearing, anyone know where it is?
11-22-2017, 05:04 PM | #5 |
I don't have a manual but figure if that spring underneath is compressed about half way it is good. Just to be sure there is a clamp underneath to hold the spring up, is that correct?
11-22-2017, 06:38 PM | #6 |
1990 Silverado Sport 2010 Silverado K1500 1996 K2500 |
11-22-2017, 09:49 PM | #7 | |
my spring was barely compressed, i think that caused a lot of play. that spring is pretty strong, i probably will have to think of a way to compress it.
11-23-2017, 11:52 AM | #8 |
Needle nose vice grips should do it.
