Old 12-17-2017, 10:22 AM   #1
bluec10
bluec10's Avatar
Windshield Washer Reservoir
This is a new one.
I fill the washer reservoir and it's empty in no time. Must have a leak. I've never come across a leaking washer fluid reservoir. Anyone else dealt with this?
Present:
2015 Tacoma. Yeah, not a GM, but I love it.
1969 GMC 32,000 - fix, drive, relax, fix...
2019 BMW R1250 GSA - Yahoooooooo
1979 Honda GL 1000 - retro touring at its best.
Past:
'05 Sierra 4x4 - Had 270,000 KM and running well when it was written-off by a stop sign runner.
'94 F-150 from the "F word" company. I'll admit it...good truck. Sold what was left of it for $800 to a guy who came to pick it up at 11:00 PM with cash in hand. Hmm.
'79 Sierra Grande (Black) organ donor - perfect rebuildable 4-bolt 350 and a good TH350.
'76 Sierra Grande (Orange) - hate isn't too strong a word. Kid who bought it turned it into a hot rod.
'68 C-10 R.I.P. - Dad's old truck...too far gone to resurrect.
'59 C-50 - with hoist. Truck is gone, wife isn't. Nuff said.
bluec10 is offline   Reply With Quote
Old 12-17-2017, 11:21 AM   #2
greasemonkey
greasemonkey's Avatar
Re: Windshield Washer Reservoir
The washer pump is located on the outside of the tank at the bottom and a likely culprit. I've had to change the pumps on my '04 and '05. The bodies cracked and let the fluid drain out.
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 12-18-2017, 02:31 AM   #3
1967GTO
If it doesn't just run out on the ground when you fill it, it could be the hose from the pump has a hole in it by the battery.
1967GTO is offline   Reply With Quote
Old 12-18-2017, 03:39 AM   #4
Killer Bee
Killer Bee's Avatar
^ yep, my '02 had a b/o hose..
one day filling it up, started peeing on the ground half way full..
figured the res was cracked, ordered replacement, and found hose when I pulled it..
thankfully, dealer took the new unmolested res back no worries
Old 12-18-2017, 09:10 AM   #5
homemade87
Dont know if this was your problem or not , but gm had a problem with battery acid deteriorating the components . The battery sits right at it . I could fill mine and it would run out until it was half full and then stop . I had parted a 04 out and had an extra . Installed it in my 06 and no more leak .
homemade87 is offline   Reply With Quote
Old 12-18-2017, 09:23 AM   #6
truckdude239
truckdude239's Avatar
Normally its the pump breaking pull back the driver side inner linner and take a look they are like 29 buxs if you need a tank dorman sells them
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
