Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Paint & Bodywork
Old 11-15-2017, 12:18 AM   #1
Alex V.
Alex V.'s Avatar
Weld seam follow-up?
A friend's van came back from the welding shop last week and will be undergoing the finish work and paint in the next month or two, myself being the primary hand in that part of the process.
He had a window out of a different van grafted into the blank driver's side, as well as an extra gas filler (also converted from gas doors to exposed caps), and, yes, a VW Westphalia camper top which will accommodate a pop-up top. The welder didn't fill the seams completely, instead leaving beads about evenly spaced, about the width of each bead (1/8-3/16") apart. For the window and gas fillers the obvious approach is feathering it out with bondo, but for the 30+? feet of welds around the top, I'm wondering if seam sealer isn't a better option. It'll see plenty of use so the most durable approach is what we're after. Input?
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 11-15-2017, 02:37 AM   #2
MARTINSR
MARTINSR's Avatar
Re: Weld seam follow-up?
Can you post some photos of the welds?
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 11-15-2017, 01:05 PM   #3
Alex V.
Alex V.'s Avatar
Ask and ye shall receive.
Alex V.
Old 11-15-2017, 03:44 PM   #4
MARTINSR
MARTINSR's Avatar
WOW!
Holy cow, that is not pretty. There is no way i would bondo over that. Clean it all, epoxy prime it, then run a strip of tape on each side a quarter inch or so away from the welds and apply a bunch of quality 2K seam sealer. It's not going to be pretty, but it will be prettier than bondo that fails anyway.
Here is a little "Basics of Basics" on seam sealer. http://www.autobodystore.com/seamsealer.shtml
Brian
1948 Chevy pickup
Old 11-15-2017, 04:51 PM   #5
mongocanfly
mongocanfly's Avatar
yikes!!!.....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-15-2017, 05:18 PM   #6
ApacheNick
First thing I would do is find a different welder...
Nick
1961 Apache short stepside 4X4 SBW 348/4 speed
1960 Apache C-20 long fleet custom cab BBW 283/4 Speed
1967 rust bucket Olds Cutlass with a 455
1972 GMC K-15 350/4 speed long fleet
ApacheNick is offline   Reply With Quote
Old 11-15-2017, 07:20 PM   #7
sprint_9
sprint_9's Avatar
I would finish welding, looks like its about half done.
sprint_9 is offline   Reply With Quote
Old 11-15-2017, 08:02 PM   #8
sevt_chevelle
Lost amongst the CORN
sevt_chevelle's Avatar
If work came out looking like that at any of the shops I worked at, you'd be labeled a hack and escorted out the door.
I'm in the camp that those welds need to be fully finished off no gap or spacing otherwise it will fail.
I hope your friend didn't pay too much for that.
Currently working on How To Videos and custom metal
70 Chevelle gettin Sliced and Diced Anything But STOCK
70 Chevelle SS455 not a typo its a BUICK BABY
49 and 72 Chevy Trucks restored to original...close to it
Drommer Stor....Norwegian for Dream Big
http://s969.photobucket.com/albums/a...lle/?start=all
https://www.flickr.com/photos/47922830@N03/
Pictures of my work and projects
sevt_chevelle is offline   Reply With Quote
Old 11-15-2017, 10:13 PM   #9
MARTINSR
MARTINSR's Avatar
The welding is UGLY but personally, I don't think it's going anywhere and I don't think it needs to be welded more. If those welds have penetrated (and they look like they have), that is plenty to hold that on. Hell the stock roof is held on with a half of those or less in spot welds.
Brian
1948 Chevy pickup
Old 11-15-2017, 10:30 PM   #10
sevt_chevelle
Brian
True, but they also are not running down the middle of a panel with a gap between the pieces either.
Cmon, Brian if a tech at the shop you work at dropped off a repair like that to the paint dept, what would the reaction be?
Old 11-15-2017, 10:52 PM   #11
MARTINSR
MARTINSR's Avatar
It's pathetic, I get that. But now, without a welder to fix it having to go back and have them put more, I guess, but I don't really see the need strength wise.
Brian
1948 Chevy pickup
Old 11-15-2017, 11:17 PM   #12
MARTINSR
MARTINSR's Avatar
I don't know, with the fact that air gets under that lid and is pulling up and down and up and down, maybe you guys are right and it needs some more welds.
Brian
1948 Chevy pickup
Old 11-16-2017, 09:57 AM   #13
Alex V.
Alex V.'s Avatar
Thanks for the input. It's not pretty, I agree; the welder said he was saving time and money by not tacking it solid, because what he put down was more than adequate - I'm not going to disagree, especially since he welded the inner side of the top channel to the inner roof of the van effectively boxing the perimeter of the roof. On the window clip he overlapped and just welded the edges down rather than butting the panels together and welding flush, but it's straight and workable so it is what it is.
I suspected seam sealer was superior to bondo in this application so I'm glad I asked. Any more input is welcome.
Alex V.
Old 11-16-2017, 11:18 AM   #14
Tiger Joe
i would fully weld everything and smooth out welds.
every custom job I have every seen that was not properly welded and just filled with bondo or seam sealer ends up cracking/lifting
Tiger Joe is offline   Reply With Quote
Old 11-16-2017, 11:22 AM   #15
MARTINSR
MARTINSR's Avatar
The thing is every factory built car on earth has spot welds holding panels on that have a seam sealer over those seams, every single car, and they aren't failing. I think it comes down to prep and proper products. Sand blasting that area even would be ideal, then epoxy primer and a quality 2k sealer.
I am not fully disagreeing with you now mind you, not even close, this is the "bestest" way and you are describing the "best" way. I just think welding it up solid is asking for more problems with warpage and a LOT more work, a LOT, LOT more work.
Brian
1948 Chevy pickup
Old 11-16-2017, 11:27 AM   #16
MARTINSR
MARTINSR's Avatar
The window welds, that is sad that it wasn't done as "good" as the gas filler. That area really should be fully welded. But now, I don't know what to tell you. It's not like up on the roof where you don't see it. A seam seal job around there is going to look like ever loving crap. And being they laid it over the top without stepping the panel so it's flush, yeow.
It would take welding up and then a BUNCH of bondo work spreading that bondo out a long way from the weld going out a foot or more to make the transition less noticeable. If it weren't done like that, there will be a big lump running around the window, you might as well just do a nice seam seal job without bondo.
But what ever you choose DO NOT apply bondo over those seams as they are, THAT would be a guaranteed failure in months, it would be a cracked mess.
Brian
1948 Chevy pickup
Old 11-16-2017, 11:41 AM   #17
72HuggerK20
I don't think I would have accepted that kind of work. When going to pick it up, I would have told him that if he's going to do half the job, he's going to get half the pay. It's amazing the kind of hack jobs people think they can (sometimes actually do) get away with.
72HuggerK20 is offline   Reply With Quote
Old 11-16-2017, 02:41 PM   #18
MARTINSR
MARTINSR's Avatar
We don't know what he as paid, it may have been $15 which is what it is worth.
Brian
1948 Chevy pickup
Old 11-16-2017, 04:15 PM   #19
Tiger Joe
Brian
I could be mistaken, but isn't the 67-72 drip rail spot welded and seam sealed, and there are plenty of trucks out there with rotted roofs.
Old 11-16-2017, 05:36 PM   #20
MARTINSR
MARTINSR's Avatar
LOLOLOL, Good one, you got me there.
You are right but it was failed seam sealer that did it, no epoxy primer, we have much better products at the paint store than the did in the factory back then. EVERY car made (with a tiny few exceptions) are made the same way and they don't fail.
Brian
1948 Chevy pickup
Old 11-16-2017, 06:30 PM   #21
raggedjim
raggedjim's Avatar
OP, I think it's a cool conversion, I hope all comes out well.
It would be great to see in when it is done, no matter how it goes.
Good luck, Rg
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
raggedjim is offline   Reply With Quote
Old 12-01-2017, 08:43 AM   #22
kiwikid
man that makes my welding look good GOODLUCK
kiwikid is offline   Reply With Quote
