11-17-2017, 04:14 PM | #1 |
Chevy to GMC Grille Swap
My 99 OBS has a worn/faded front end. Despite my love of Chevy's, I'm a "less is more" type & don't care for the Bowtie in the center bar. I'm planning to swap to a fresh GMC grille & was curious if other parts need to be swapped as well. Depending on what is correct on the NET, some say other items require swapping, while others say no.
Anyone that's done the swap on a 94-98, please advise. Thanks!
11-17-2017, 07:48 PM | #2 |
Re: Chevy to GMC Grille Swap
Head lights and turn signals are the same. The 4 corner lenses are different between Chevy and GMC.
The filler between the bumper is the same between makes. So is the core support. All you need is the grill and the corner lenses. |
11-18-2017, 10:40 AM | #3 |
Yep. As long as you're sticking with a '94-'98 GMC grille, all you'll need are the grille and corner lenses. Everything else is the same.
11-18-2017, 08:19 PM | #4 |
Excellent! My plan was to replace all the lighting lenses so I figured thats the perfect opportunity to update to a fresh grille w/o a badge. They will compliment the new impact-strip free bumpers already swapped on.
Thanks guys.
12-04-2017, 12:21 PM | #5 |
Rollin' Old Skool
Yep, what those guys said! I don't mind the Chevy grille but prefer the GMC version as well. What are you planning for the light replacements?
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
12-04-2017, 03:42 PM | #6 |
Just direct replacements. I'm not a fan of the LED trend lighting (I like the factory appearance).
12-05-2017, 03:44 AM | #7 |
Rollin' Old Skool
Same here, at least when it comes to exterior lighting lenses. If you don't mind, report back with where you purchase the new lights & your thoughts on them.
12-05-2017, 08:23 AM | #8 |
Don't Crush em Restore em
I have a '98 and was thinking I would like to do the same thing at some point, Scoti please take pictures of the finished product.
TexasJeff 2009 Silver with Linen Interior Cadillac DTS 1990 Red with White Top and Interior Ford Mustang GT convertible 1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually |
12-05-2017, 08:54 AM | #9 |
Rollin' Old Skool
If you'd like to look, I have some before/after pics of my old truck that I did the grille swap on.
12-05-2017, 10:32 AM | #10 |
I've used TYC Genera lenses in the past. Their tail lights fit like OE vs the other common supplier from LMC.
12-06-2017, 12:01 AM | #11 |
Countdown Survivor
I like the GMC grille better also. I've changed a few, the info above is correct, nothing to it with the right stuff.
93 Yukon 89 Silverado Z71 SWB Sport 91 K 2500 Silverado "Lobuk-Worktruk" A MAN OF HONOR DOES NOT LIE, CHEAT, OR STEAL, NOR TOLERATE THOSE WHO DO. Gettin' old ain't for sissies. |
12-06-2017, 03:45 AM | #12 |
Rollin' Old Skool
I bought a pair of TYC tails on Amazon. I don't recall them being Genera though. I had them custom painted but ended up with one not coming out exactly as I want. So, they're about to get redone. What mfg are you looking at for the headlights/parking lamps?
12-06-2017, 09:22 AM | #13 |
Based on the fit quality vs the other brand from LMC (Depot?), I'm looking @ the TYC front lighting group as well. Let's just say I had to do multiple set's of the LMC rears because of poor alignment quality. When you would go to tighten them down, they would be in a bind & chipped the corners on a lens (2 different sets). Despite understanding the problem, it still repeated itself.
I tried the TYC's on the 99 as my local Oreillys had a pair on the shelf. They went in as easy as the factory pieces came out. Zero issues.
12-06-2017, 12:41 PM | #14 | |
Rollin' Old Skool
12-12-2017, 05:48 PM | #15 |
Good info here. I would like to do the same with my 96 truck, so that's nice to know.
12-12-2017, 07:02 PM | #16 |
I replaced my rear lenses with the TLC brand .... BE CAREFUL....
The upper corners of the lens are very brittle & a bit thinner than factory. The first lens I installed broke at the upper corner as it just pressed against the soft rubber weather strip. ( O' Reilly parts swapped it) I was more careful next time.
'70 GTO Midnight Blue '88 GMC Sierra SLE 392,000 miles-(2018) sold to Classic car shop in Germany. '93 Cadillac STS Black '93 Mercedes SL 500 Teal '86 Yamaha FZ750 - 15,000 RPM '86 Yamaha FJ1200 - Criminally Fast 2016 Ferrari 488 GTB, I drive it - don't own it. '05 GMC Yukon XL , SLT 4wd ( just purchased 2018) |
12-12-2017, 07:57 PM | #17 | |
