Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 05-15-2017, 10:26 AM   #1
ct67_72
ct67_72's Avatar
Truck 12B Rebuild package with gears and limited slip $775
Complete rebuild/regear package for your truck 12B
Gear ratio of your choice.
Yukon Duragrip Limited slip differential. (3.73+) Auburn, and eaton 3.54 down carriers also available.
Axle bearing and seal kit.
Master differential rebuild kit. Complete with all bearings, races, seals, ring gear bolts, marking compound etc.
Order through the 19th of May and receive a $40 mail in rebate on the Yukon Duragrip.
Dan.
Drivetrain parts and accessories.
68 medium green shortbed fleetside
ct67_72 is offline
Old 05-06-2018, 08:28 PM   #2
G-NUT
G-NUT's Avatar
Re: Truck 12B Rebuild package with gears and limited slip $775
I know this is a year old but do you have something like this for a 10 bolt?
'84 Suburban C10 Silverado - laying pinchweld to the ground on 22/24.
/Porterbuilt / Accuair / Bonspeed / Landsail / Auburn Gear / Richmond Gear / Moser / Raybestos / ProMaxx / Edlebrock / Street Demon / Taylor Wire / K&N / MSD / KillMat /
SOLD: 1985 GMC Sierra Classic 2500 3+3 Crew Cab Long Bed
G-NUT is offline
Old 05-06-2018, 08:37 PM   #3
ct67_72
ct67_72's Avatar
Thats ok, Im still here and still offering deals on drivetrain parts! I can certainly put a package together for the 10b. What ratio are you looking for?
Dan.
ct67_72 is offline
Old 05-06-2018, 10:41 PM   #4
G-NUT
G-NUT's Avatar
3.42 or 3.73. Prefer 3.73. I'ts a 10b out of an 84 C10 that sat up about a year before I got the rear axle. It has the 28 splines and an open diff. I'm going to have it narrowed 1.5" per side. Since I'm having that done, I'd just like to install a traction lock unit, different gear set and replace all bearings and seals.
G-NUT is offline
Old 05-07-2018, 12:50 PM   #5
G-NUT
G-NUT's Avatar
Just checking in.
G-NUT is offline
Old 05-07-2018, 02:36 PM   #6
68Stepbed
68Stepbed's Avatar
Also interested in a package for a 10 bolt for an 05 Sierra.
3.90 R&P
Eaton or Yukon LSD
Bearing, race, seal, and gasket kit
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline
Old 05-12-2018, 10:27 PM   #7
Clyde65
Clyde65's Avatar
Price for the Duragrip LSD only??
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 05-13-2018, 08:52 AM   #8
ct67_72
ct67_72's Avatar
3.90 R&P
Eaton or Yukon LSD
Yukon Duragrip limited slip. $468
YUkon master install kit $153
YUkon gears, whichever ratio $253
Dan.
ct67_72 is offline
Old 05-13-2018, 08:53 AM   #9
ct67_72
ct67_72's Avatar
12b Duragrip only, $365
Dan.
ct67_72 is offline
Old 05-21-2018, 08:37 AM   #10
jessemthompson
Looking for a 12B true track with an install kit. Current gears are 3.73s.
jessemthompson is offline
Old 05-24-2018, 08:21 AM   #11
ct67_72
ct67_72's Avatar
$663 to your door
Dan.
ct67_72 is offline
Old 05-28-2018, 12:39 PM   #12
darkhorse970
darkhorse970's Avatar
Yukon Duragrip, install kit, and 3.42 for 1980 12 bolt price please.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline
Closed Thread
