11-24-2017, 10:29 PM | #1 |
replace 72 rear with a 68 drum to drum on my
I'm going to swap out my complete 72 posi rear thats making a lot of noise with a 68 drum to drum posi i know they are a couple inches shorter end to end than the 72 is there anything besides the brake line plumbing that will be an issue that i should be aware of ....
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
11-24-2017, 10:32 PM | #2 |
Re: replace 72 rear with a 68 drum to drum on my
doing this on my 72 c10 rear came out of a 68 burb
11-24-2017, 11:16 PM | #3 |
Moderator
The brake lines will plumb right up with a little bending. I did the opposite and put a 72 rear in my 68.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
11-24-2017, 11:50 PM | #4 |
BlahBlahBlah
Maybe I miss understood the process you are going through. To me the obvious difference is 5 lug to 6 lug unless you are doing something with the axels Im not getting.
11-25-2017, 12:28 AM | #5 |
Why not sell the 68 posi rear and use the money to fix the one in your truck.
Have you checked the pinion nut? They get loose and make a lot of noise, mostly on decal I believe. Its not the best solution but usually you can tighten the pinion and it will be lots better. Posi additive, if its a crunching noise. |
11-25-2017, 08:41 AM | #6 |
thanks everyone . Had this used POSI unit ""professionally" installed 3 years ago bearings seals axle seals the whole enchilata , I had 2 i bought from board members, we picked what we thought was the best out of the 2 from the get go iI had the clunking going on pretty significant making the turns felt like the rear was going to jump off the frame . I replaced the gear oil put the additive went with the purple stuff etc. Some improvement was noted but still significant clunking on the turns only, so now i have about 15k on it and i been hearing some different noises and feel i slight vibration coming thru i believe the drive train up to my hands on the steering wheel So i have a few options the easiest is to make the swap Im back on the road again pretty quick ...I have 6 lug rallies so im covered there , I get to clean ,rattlecan rebuild , complete brake job , and test drive the 68 rear this came out of a driver so we have some history. So Like Paul Harvey said....." now you have the rest of the story.".... as usual I appreciate the comments will keep all posted with my results
JZ
12-18-2017, 10:56 PM | #7 |
UPDATE
I decided to use this open rear I was saving for another project cleaned it up new brakes ,lines, Ebrake cables installed under my 72 and very pleased ..now i want to take that 68 posi unit and set that up for my other project (69 short bed fleet) convert to 5 lug axles and i may as well do the disk conversion while Im at it. any recomendations on axles / disc conv.? Im not sure I want to put big brakes on because I would like to stay with 15 inch rallies I know the rear is more narrow so I can put some fatter tires with the right back space without tubbing I already have 5 lug drop spindles for up front ...
12-22-2017, 10:32 AM | #8 |
Hey Jess, if u decide to sell the 68 posi keep me in mind.
A very merry xmas & happy healthy new year to u & urs! Scott
1963 C10 swb fleetside 1966 GMC G1000 Handi-bus (future project) 1955 Chevy 2 dr. wagon |
12-22-2017, 11:02 AM | #9 | ||
"I ain't nobody, dork."
If you use 71-72 axles in a 67-70 housing you will have problems as the axle shafts are too long.
Gary
12-22-2017, 08:40 PM | #10 |
thanks Scott thank you Merry Christmas to you and family too Im gonna hold on to this rear buy 5 lug axles ( the right length ) couple hundred might do the rear disc conv. while Im at it..... ill keep you posted
12-24-2017, 02:33 PM | #11 |
Have you thought about having a good machinist redrill your axles to the bolt pattern you want? A friend did this on his '64. Went from 6 on 5.5 to car pattern 5 on 4.75. It worked great and was cheaper than new axles.
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
12-26-2017, 11:21 AM | #12 |
Early axles are 30.5 in long measured from the end of the splines to the wheel mounting surface. Late axles are 31 5/16 in this same spot. Just an easy way to tell if you buy them used, and/or to make sure you buy the right ones.
12-26-2017, 05:34 PM | #13 |
"key word here is good machinist" im going to see if i can get that done and what the cost is thanks for the info sounds like a good option
12-26-2017, 05:38 PM | #14 |
when you say late, you mean 71-72 ? ,I have some options to look at ..before I shop them new im going to pull and measure thanks for that info
12-29-2017, 11:33 PM | #15 |
ACT II
clean this up pull the axels and have it blasted
12-29-2017, 11:40 PM | #16 |
I need some recomendations on rear disc conversion the truck im going to use this rear on will be an automatic ....but i still want e brakes i like the drum type in the rotor any suggestions would be helpful
