02-24-2018, 11:24 AM | #1 |
Front A-arms bushings, things '71
I've never seen this before they are not rubber, well they don't look like rubber and have a grease zerk.
What are these and how do they work, are the like king pin bushings made of metal? Do you test them for good/bad the same way as a rubber A-arm bushing? |
02-24-2018, 01:16 PM | #2 |
Who Changed This?
Re: Front A-arms bushings, things '71
Lower a-arm bushings are metal nuts with a coarse thread, thus only get grease. The upper a-arm bushings should be neoprene but could have been replaced with polyurethane.
02-24-2018, 10:16 PM | #3 |
The only way I know to check them is to use a spring compressor to take the pressure off of the lower control arm and try to wiggle the arm forward and aft looking for movement of the shaft in the bushing. A dead blow hammer helps. As does removing the wheel. If you can't see any movement they are good, really bad ones like the ones on my Burban flop around a 1/4" or more.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
