06-06-2018, 07:33 AM | #1 |
HELP! BBC 496 Falls Flat
My 496, with new extreme energy cam, and aluminum heads, holley 750, falls on its face when I tromp it, about 3rd gear, its like the gas shut off, if I let up on throttle, it comes right back...around 4000 rpm, it revs past 4000 in 1st and 2nd, Any idea's anyone? I have Holley sniper to install, but want to be sure everything is right beforehand
06-06-2018, 09:12 AM | #2 |
Re: HELP! BBC 496 Falls Flat
What is the cams specs?
Which Holley 750? Double pumper or vac secondary? What’s your timing curve like? |
06-06-2018, 11:57 AM | #3 | ||
"I ain't nobody, dork."
What fuel pump? Where is your tank located? What rig is it in? What intake manifold? Do you have a stall converter?
Gary
06-06-2018, 01:15 PM | #4 |
06-06-2018, 02:38 PM | #5 |
87 R30 CC Dually, TBI 454, NV4500, zero rust barn find 87 Jeep Grand Wagoneer, 6.5 turbodiesel, 700R4 |
06-06-2018, 02:54 PM | #6 |
06-06-2018, 03:21 PM | #7 |
Fuel delivery issue could be pump, fuel line size or a partially plugged or restrictive filter. I think you are on the right track.
Blake |
06-06-2018, 04:53 PM | #8 | ||
I'd say a different pump. Especially if you're gonna install a Sniper.
That 496 needs fuel! Gary
06-06-2018, 08:23 PM | #9 |
i ran a stock pump on my 468, made aboot 550 horse. I start checking other things. But could be a weak pump...
06-07-2018, 01:01 PM | #10 |
Did you buy the sniper with the required fuel pump ? Install the electric fuel pump from the sniper, install a regulator and connect it to the carb. That much closer to the sniper EFI ......
06-07-2018, 01:30 PM | #11 |
Yes but Also bought a sump because of no return line to gas tank, wanting to get running right before swapping to Sniper
06-07-2018, 02:27 PM | #12 |
I was only trying to save you money on buying another stock pump. But I guess it’s only money. Good luck...
Posted via Mobile Device |
06-08-2018, 07:42 AM | #13 |
Thanks, I have a larger pump to put on, going to install before sniper to see if its the problem, had pump ordered but did not show before setting motor back in.......
06-08-2018, 07:43 AM | #14 |
06-08-2018, 09:38 AM | #15 |
Check the sock in the fuel tank.
68 c10 swb stepper 68 c10 swb stepper 67 c10 lwb 06 gmc duramax |
06-08-2018, 11:55 AM | #16 | |
However, I've learned that " Self- tuning" regarding the Holley is very misleading. Yes it will fire up and run ok, but, if you want it to run like it came from the factory this there's alot of learning YOU have to do (or pay someone to tune, preferably on a Dyno). The tuning manual for it is 45 pages long if that gives you a hint. |
06-08-2018, 01:33 PM | #17 | |
06-08-2018, 03:09 PM | #18 |
Applebmw,
For the most part, yes. There are a few design issues that need fixed; notably the linkage. Stock, both throttle blades open simultaneously. This makes for a super stiff and extremely sensitive pedal. It's horrible if your using a standard trans! However, Holley has a $5 fix that replaces the link and allows it to be progressive (like all thier carbs). It's just a matter of swapping it out. Unlike a 4150 carb, it requires some programming changes in the unit. And of course, being electronic, it requires a firmware update for the ECU and the handheld display. I strongly suggest you start browsing the sniper forum on Holley's website. It's a wealth of information. RFI is another issue folks are having but there are easy fixes. It's nice knowing these things before you do an install and end up angry and frustrated. After all, this things $1000.00! I expect it to work as advertised. Otherwise, I'm very happy with it so far. |
06-09-2018, 12:01 PM | #19 |
Have you changed the fuel pump yet ?
06-09-2018, 04:46 PM | #20 |
