06-07-2018, 09:13 PM | #1 |
low n' slo
Grant hinges
bought some basic grant hinges (like 5 yrs ago) to use on my suburban and im finally putting them on. i followed 5windowpickup's thread since he used them. mine did not come out near as clean as his. very hard area to weld and u need precision measuring for it to be flawless like his, there is no template. with that being said, i got mine welded in and the hood actually closes, opens, and latches perfect. my issue is when i when inopen and close it, then skin that the hinge is welded to flexes a little...
im not sure if this is normal...but i dont see any other way to run it like this. unless i weld a supporting bracket from behind the skin to the other side of the cowl. just wanting to get anyones thoughts or see if anyone else had this issue. thanks!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
06-08-2018, 09:16 PM | #2 |
Re: Grant hinges
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
06-08-2018, 09:31 PM | #3 |
Re: Grant hinges
^ Lmao.
Post some pictures! |
06-08-2018, 10:22 PM | #4 |
low n' slo
Re: Grant hinges
i didnt take any pics but its on first page of this build. i have the same hinges..but the part he painted black after instal is the part that flexes a little. now, i still haven't put the screws in that goes on top of the cowl to the body so maybe that will help?
http://67-72chevytrucks.com/vboard/s...d.php?t=365912
