Old 08-02-2018, 10:21 AM   #1
65blackfleetside
65blackfleetside's Avatar
Can Someone tell me what this electrical plug is for on Oil Pan?
You guys rock I could never finish this build without this form!!
So I am looking for an oil port to install my aftermarket electronic oil pressure sending unit. The cover plate drill and tap method next to oil filter is a no go- aftermarket header pipe is way too close.
This large plastic hex nut plug is located below the starter on the oil pan.
LS motor is 2005 Truck LS3 5.3. There is no lead from my new BP harness for this plug. Not sure what the factory GM intent was for it?
current ride 1951 AD Chevy 5 window 2004 LS Gen 3 [/B]
1965 fleetside Sold
65blackfleetside is offline   Reply With Quote
Old 08-02-2018, 10:48 AM   #2
nsb29
nsb29's Avatar
Re: Can Someone tell me what this electrical plug is for on Oil Pan?
Is for your oil temperature there is a sending unit at the back of the motor for oil pressure the same place as a small block
nsb29 is offline   Reply With Quote
Old 08-02-2018, 12:34 PM   #3
65blackfleetside
So this used for Oil temperature? is this port too low on the block to put an after market oil pressure sending unit? I need to install the one that goes with my after market gauge set.
Correct me if i am wrong? :
I need to run 2 oil pressure sending units: one for the OEM style LS harness -located near firewall top back of block. and the one for the after market gauge set with matching ohms range of oil pressure gauge. This other sending unit came with my gauges set.
1965 fleetside Sold
Old 08-02-2018, 01:20 PM   #4
greentruck
greentruck's Avatar
There is no oil pressure provision wired into the BP harness unless you specifically requested it . No need for two sensors. Just switch out the existing oil pressure sending unit with the one that came with your gauges and run that right to the gauge or control box. Read page 9 of 12 in the BP instructions.
For some people driving is one long series of corrections...
greentruck is offline   Reply With Quote
Old 08-02-2018, 01:26 PM   #5
Macdaddy1
Just did this on my 5.3 ls swap. I had to buy an adapter for the autometer oil sending unit that screwed into the back of the block where the original 5.3 oil sending unit was located.
Macdaddy1 is offline   Reply With Quote
Old 08-02-2018, 02:33 PM   #6
65blackfleetside
Got it thanks guys.
I assumed the ECM needed oil pressure readings? I will unscrew the OEM Oil Send unit and replace with the aftermarket gauge sending unit. My gauge kit came with some thread adapters.
1965 fleetside Sold
Old 08-02-2018, 02:39 PM   #7
greentruck
greentruck's Avatar
Yup. I used Dakota Digital gauges and both the temp sender and oil sender came with adapters. I ended up putting the temp sender for the Dakota Digital in the passenger side head and leaving the stock sender in the drivers head for the PCM.
Old 08-02-2018, 03:05 PM   #8
Willie Makeit
Willie Makeit's Avatar
that is an oil LEVEL sensor, not an oil temperature sensor.
Willie Makeit is offline   Reply With Quote
Old 08-02-2018, 07:24 PM   #9
NC_John
NC_John's Avatar
Yep!
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 08-03-2018, 12:21 AM   #10
truckdude239
truckdude239's Avatar
Oil level
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 08-03-2018, 08:05 AM   #11
greentruck
greentruck's Avatar
Do any of you guys use the oil level sensor on your swaps?
Old 08-03-2018, 09:27 AM   #12
ls1nova71
ls1nova71's Avatar
No. That's for people who don't know how to open the hood. The level has to be lower than any gearhead would allow his engine to get for it to turn on the light....
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 08-03-2018, 09:31 AM   #13
greentruck
greentruck's Avatar
Gotcha. That's what I figured.
Old 08-03-2018, 09:46 AM   #14
ls1nova71
ls1nova71's Avatar
To be honest, I did hook it up on my first swap in my Nova, but it has never come on, so seems kind of pointless now!
Old 08-03-2018, 10:08 PM   #15
sprint_9
sprint_9's Avatar
It comes in handy if you have an early gen 4 with DOD, I had one that burnt so much oil it would come on around 900 miles. Under half or more throttle conditions it would have enough oil up in the motor that it would trip that sensor, about 2 quarts low.
sprint_9 is offline   Reply With Quote
