Old 09-09-2018, 03:07 PM   #1
72blazer_mud_bogger
72blazer_mud_bogger's Avatar
Dana 60 Axle shafts
This may be a stupid question but are the axle shafts the same between ford chevy and dodge on the 70s and 80 Dana 60 front axles. I know that for is opposite on drop side and reverse cut gets but will the axle shafts out of ford or dodge work in a chevy D60
thanks in advance
72blazer_mud_bogger is offline   Reply With Quote
Old 09-10-2018, 06:34 PM   #2
Mike C
Mike C's Avatar
Re: Dana 60 Axle shafts
Most likely, no. Better answer? Maybe. There are all sorts of differences in spline count on not just the carrier (30 versus 35 spline) and the u-joint. In addition to overall length. And stub axles length versus spline count.
You will have to know the year of whichever axles you are pondering swapping and cross reference to see if any of the parts will interchange.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
