Old 12-15-2018, 12:04 AM   #1
Nick_c10
Ls oil pan
About to install a 04 5.3 Truck LS in my 68 stepside and was told the oil pan will fit but will hang too low for a lowered truck. Anyone know if the f-body pan will work? I can tell by looking at it that it will be short enough but the lower sump part is longer and I’m not sure if it will clear the cross member. I’d like to hear from someone that has installed it on their swap before I spend $300 on it off eBay. I’ll be using dirty dingo mounts. Thanks.
Nick_c10 is offline   Reply With Quote
Old 12-15-2018, 03:30 AM   #2
ls1nova71
ls1nova71's Avatar
Re: Ls oil pan
It will fit, but you have to put it pretty far back. A better pan is a CTSV pan or even the GM Muscle car pan.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 12-15-2018, 09:38 AM   #3
1971Stepside
Almost Satisfied
1971Stepside's Avatar
Re: Ls oil pan
Second the CTSV pan.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 12-15-2018, 12:36 PM   #4
mongocanfly
mongocanfly's Avatar
Re: Ls oil pan
I used a c6 vett wet sump pan...it was the shallowest one I could find with my research...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 12-15-2018, 12:43 PM   #5
Nick_c10
Re: Ls oil pan
Thanks guys, ordering one now.
Old 12-15-2018, 07:28 PM   #6
bigmoe
bigmoe's Avatar
Re: Ls oil pan
Where are you getting it from? Do you also need pan + matching pickup, dipstick, windage tray?
I'm probably in the same boat with my 65 C10, 3" drop spindles, 2008 5.3 LS from a Tahoe. I'm going with the adapter plates on the engine that allow you several positions. I assumed I would put it back as close to the firewall as possible to keep more room up front.
bigmoe is offline   Reply With Quote
Old 12-16-2018, 10:41 AM   #7
1971Stepside
Almost Satisfied
Re: Ls oil pan
If you go CTSV pan you need the pan, pick up tube, dipstick tube and dipstick. The wind age tray is the same. If you need the part numbers let me know. I can find my receipt
Old 12-16-2018, 10:46 AM   #8
bigmoe
bigmoe's Avatar
Re: Ls oil pan
Sure that would be great.
Old 12-16-2018, 12:26 PM   #9
1971Stepside
Almost Satisfied
Re: Ls oil pan
CTVS Pan part #12631828 comes with new bolts and gasket
Pick up Tube #12621299
Dipstick tube #12584738
Dipstick #1258437
Windage tray (if you want it) #12611129
