01-25-2019, 02:47 PM | #1 |
Spark Plug Heat Shields
I'm putting in a new crate 350 in my 1978 K20. I was going to switch over the original spark plug heat shields from the old motor onto the new crate but one of the four is too badly damaged to reuse.
1. How important are they? Someone told me new spark plug wires are better and the heat shields are less important. Not sure that sounds right... Anyone run engines without them? I have the original cast iron exhaust headers. 2. The heat shields are also very hard to install since the exhaust manifolds are in the way. I have seen some people that have "two piece" ones that would be way easier. They look like JEGS Part Number: 759-DESPB12 but Jegs said they wouldn't fit my Gen 1 350. Thoughts? Thanks! -Will
1978 K20 Camper Special, stock 350, TH400, np203, 265/75R16, GMC 10.5" rear, Dana 44 front 3.73, Q-jet. |
01-25-2019, 09:17 PM | #2 |
Re: Spark Plug Heat Shields
I always took them off and threw them away all my life. They got in the way of plug changes and cut my fingers. If I got a truck with them today I might leave them on and rough it on the plug changes. I don't think they are really needed though. When I used to mud bog my K20 the spark plug area would get caked right full of mud and the exhaust manifolds held it in there nicely. The truck still purred like a kitten without a misfire at all. So yeah spark plug wires are a lot better nowadays.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
01-26-2019, 01:32 PM | #4 |
As I recall, the spark plug shielding and shielding over the distributor in Corvettes were supposed to be for reduction of radio interference. I think the shielding does more to protect the spark plug wires. Since wires are now of better quality, and some are silicone, that might not be an issue today.
01-27-2019, 05:27 PM | #5 |
I put them all back on my last rebuild, before that I had to put sleeves on the plug wires to keep them from getting too hot near the manifolds. I also got them from a Corvette parts supplier so they were the correct ones. No issues with the plug boots now.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
01-27-2019, 07:23 PM | #6 |
01-27-2019, 11:09 PM | #7 |
Thanks! Im going to go with the reproduction ones. Id like to keep the original look and if they are still important Ill have them.
01-28-2019, 11:53 AM | #8 |
i have them on my 1ton 4x4 work truck . i have seen lots of burnt boots over the years and was not about to have a set of my own .
that little air gap between the manifold and the shield does help drop temps a lot .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
01-29-2019, 03:23 PM | #9 |
Just a couple pictures of the heat shields installed on my 350. I think I got them from Rik's Corvette Parts.
01-29-2019, 05:40 PM | #10 |
Thanks for the pictures. The key is the front two look like they are in two pieces (held together with that machine screw) so you can install them with the exhaust manifold in the way. The back two are one piece since they are easy to get at. I think the ones I ordered are the same.
01-29-2019, 06:06 PM | #11 | |
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
01-29-2019, 08:03 PM | #12 |
if i recall the older had ear's to pick up the manifold bolts .
and i just installed a 1996-2003 vortec 5.7 engine and it had the 4 bosses drilled and tapped for the newer style .
01-30-2019, 09:50 AM | #13 | |
Tags |
heat shield |
