Old 04-30-2019, 07:40 PM   #1
trac209
Timing showing way off tab...wits end
Ok so here is my issue,I recently rebuilt my engine. Bored,rings,bearings new cam,heads etc. Other than that everything from old engine is being used. Issue is when a timing light is connected (vac advance disconnected). The timing mark shows at 12 o clock position way off tab with timing light. Also tried another light same results. I have verified tdc using a stop and by compression and the balancer mark is right on zero on tab. The engine will not run when I retard timing to get near the tab. Engine starts well and doesn’t kick back or ping and revs up nicely. Doesn’t ping under load in gear either. I can’t for the life of me figure out why this is happening, I have even locked the weights in the distributor and it ran bad under load so engine doesn’t seem to be running at an actual 38-40 degrees initial timing. Any insight would be greatly appreciated.
trac209 is offline   Reply With Quote
Old 04-30-2019, 07:58 PM   #2
tdangle
tdangle's Avatar
Re: Timing showing way off tab...wits end
Couple of possible solutions.
1. you have a dial back type timing light and it is messed up. I would verify with another timing light (opps did't read your post closely enough)
2. Are you really hooked to #1 SBC cyl 1 is drivers side front of engine.
3. timing ring had shifted on your balancer
Terry
1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC
tdangle is offline   Reply With Quote
Old 04-30-2019, 08:04 PM   #3
trac209
Yes on number one cylinder,no balancer hasn’t shifted keyway is in line with mark on balancer. Old setup was perfect with this same balancer. If balancer shifted tdc wouldn’t line up with tab 0 mark.
Old 04-30-2019, 11:11 PM   #4
YoungPup1977
So before working on the engine as you stated above, when you set the timing before the rebuild, the mark was different than what you are seeing today ??
Some SBC's are timed straight up on the timing cover....
How did you set the timing before your rebuild....what changed, timing cover ? balancer ? reused all old parts ? Anything changed ?
YoungPup1977 is offline   Reply With Quote
Old 05-01-2019, 08:34 AM   #5
cadillac_al
Yup, trac must not have timed the engine before the rebuild. It sounds like the classic wrong balancer/timing cover combo.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 05-01-2019, 09:18 AM   #6
garyd1961
Except he says timing mark is zeroed with #1 TDC.
garyd1961 is offline   Reply With Quote
Old 05-01-2019, 11:53 AM   #7
trac209
Finally someone who actually read the post through. Balancer has not been changed or shifted as stated in op. Previous engine was also timed. I’ll figure it out thanks.
Old 05-01-2019, 12:12 PM   #8
YoungPup1977
LOL !!!!! Please let us know what you find !!!! I love these trick questions and its like a treasure hunt.... its so exciting.
Did you do all the work ? so you should know what you did wrong....right ?
GOOD LUCK !!!
Oh I missed the comment "previous engine" which implies its not the original engine ? correct ?
Heres one for ya... put ground shielding on your plug wires and make sure you get a good ground to ground the shielding to. Must be still winter in Canada....
Old 05-01-2019, 06:34 PM   #9
trac209
GOOD LUCK !!!
Heres one for ya... put ground shielding on your plug wires and make sure you get a good ground to ground the shielding to. Do know any thing about RF waves ?? You ever get cross talk on your old land line on your phone ?? Look it up thru google. Short transmit to receive on the two wire circuit on your phone and u get dial tone. Lol!!!!!
Previous engine means before rebuild as stated in op.
Old 05-01-2019, 07:01 PM   #10
rsavage
rsavage's Avatar
Does your timing cover have a tab at 12 o'clock right under the water pump that can barely be seen ? Did you add an aftermarket timing tab on the cover at the 5 o'clock position as small blocks often have or add a different timing cover? It can appear as that the distributor is in correctly and it is on number one and TDC on the lower tab when in fact the TDC should be on the upper tab under the water pump. Balancer crank keyways determine what tab is used.
Happened to me. I put the motor together, didn't see the almost hidden tab and added an aftermarket timing tab. Had that distributor in and out several times 'till I finally figured it out.
1961 C1 Corvette
1959 El Camino 350 TPI, 9" 4 w disc
69 Blazer K5 - sold July '20
2021 Durango RT 5.7
rsavage is offline   Reply With Quote
Old 05-01-2019, 09:30 PM   #11
trac209
No cover and tab are original and have not been changed. All posted in response are a moot point since the mark on the balancer points to 0 on the tab.
I’ll post what this issue is when and if I find it. My original post has addressed every question people have asked.
Old 05-01-2019, 09:42 PM   #12
Feel the 'Pane
Are you using the same crank? Or maybe the cam gear (distributor end) is off index from the old 1?
Like trac209 says, he'll figure it out... Head scratcher for sure!
76' GMC K25 Sierra Classic Camper Special: propane powered 350ci/NV4500/205/D44/SRW 14B/4:10/tach,tilt,a/c - daily driver
77' GMC K35 Sierra Grande C/C: 350ci/SM465/205/D60/narrow 14B DRW/4:10
Flatbed
82' Chevrolet K30 C/C: 454ci/SM465/205/D60/narrow 14B DRW/4:56
Flatbed, 6"Rancho, Alcoa's
Feel the 'Pane is offline   Reply With Quote
Old 05-01-2019, 09:52 PM   #13
Feel the 'Pane
OK, so I'm old & have a bad memory, but I've done hundreds engines & once, I had a belt timed ohc straight 4 that ran 'OK', but wasn't doing near what it should. Found that some gas station mechanic had replaced the timing belt 1 tooth off. Retarded cam timing 8° & ran, but lost power @4k instead of 6.5k (redline).
Put the belt where it SHOULD have been & it ran like a raped ape.
Is it possible that your cam gear (timing chain) is off 1 tooth?
Flatbed
Old 05-01-2019, 10:09 PM   #14
Greasey Harley
Greasey Harley's Avatar
Timing chain advanced one tooth?
Cam not ground properly?
Did you degree the camshaft when you installed it?
Greasey Harley is offline   Reply With Quote
Old 05-01-2019, 11:22 PM   #15
truckster
truckster's Avatar
I've been wracking my brain since your first post. This is really a mystery. The only thing I can come up with is maybe the cam...
How is the power compared to what you expected? If the cam is off, it could still run, and the ignition timing would be off, but it should have a noticeable power loss.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson
truckster is offline   Reply With Quote
Old 05-01-2019, 11:35 PM   #16
Captainfab
60-66 Nut
Whether the cam was installed advanced or retarded, it is not going to change the ignition timing only the valve timing. Since the OP has verified #1 TDC and the the rotor is at #1, I would suspect something screwy is going on with the distributor.
Old 05-02-2019, 04:29 AM   #17
Feel the 'Pane
Uumm, if the OP is talking about a SBC, ignition timing is driven by the cam.
Flatbed
Old 05-02-2019, 07:36 AM   #18
rpmerf
rpmerf's Avatar
Yes but you can adjust the distributor independent of the cam timing. Even if the cam is off a tooth, you can get the distributor where it needs to be.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 05-02-2019, 07:54 AM   #19
rpmerf
rpmerf's Avatar
The balancer is made up of multiple pieces. There should be a rubber layer in there. If that has deteriorated, the center section will line up on the crank, and it will look fine when the engine is off, but can move once the engine is started. I would try moving the outer ring of the balancer to be sure it is tight to the center section and there is no play.
edit:
The crank pulley bolts to the center section. mark TDC on the crank pulley and see if it lines up with the balancer while running.
1997 GMC Suburban
Old 05-02-2019, 07:55 AM   #20
YoungPup1977
What vehicle is this SBC in ? I am assuming its a SBC, no where have you indicated what engine it is..... its a Chevy correct ?
baby steps one question at a time...….
Year Make Model CID please...
Old 05-02-2019, 08:22 AM   #21
trac209
Yes Sbc,look no offence intended but I’m just gonna stop replies to this thread as nobody has either taken the time to read through original post or they know zero about engines and timing.
Old 05-02-2019, 08:55 AM   #22
YoungPup1977
LOL!!!! No where in your information talks about what vehicle or engine so if you want any help from me I need you to answer the questions I asked, if not its still your issue...… WOW dude !!! must be still cold up North...
By the way no offense intended in return but its really your issue and if you want help you are going about it the wrong way !! To say in this forum, read thru the OP....well where in your OP does it indicate what engine year make of vehicle.....you want us to help but wont give up information so I can help you
Cant even answer my simple question year make model CID.....so we know what we are working on....the forum deserves folks like you when you state no one knows about engines and you are going to STOP replying...LOL!!! WTH, is this kids corner or something....LOL!!!!!!
I wont reply any more....LOL!!!!! I don't know what your working on...most likely its a FORD !!!! You offended....LOL!!!!
What a joke dude !!!!
GOOD LUCK !!!!
Old 05-02-2019, 10:06 AM   #23
SunSoaked
SunSoaked's Avatar
I can't stop thinking about how a raped ape runs. A video would be most helpful. Lol.
SunSoaked is offline   Reply With Quote
Old 05-02-2019, 11:43 AM   #24
tdangle
tdangle's Avatar
All I can say is good luck after your last post/comment.
Terry
Old 05-02-2019, 01:04 PM   #25
Feel the 'Pane
I guess that shows how old I am...
"That thing ran like a:
scalded dog
raped ape
Flatbed
