10-01-2019, 08:49 PM | #1 |
1957 gas tank
I just ran out of gas and I filled it up 14 gallons. I've seen some new tanks advertised at 15 gal and others at 17 gal, what size are they? Maybe 2 sizes?
1957 CHEVY 1/2 TON SHORT BED 1940 FORD 1/2 TON SHORT BED |
10-02-2019, 01:02 AM | #2 |
Re: 1957 gas tank
There are several different sizes. Mine's a 17 gallon, but they go up 25 .
10-02-2019, 01:16 AM | #3 |
Re: 1957 gas tank
Just because you ran out doesn't mean the tank was bone dry...there could easily be a couple gallons below the pickup tube...depending on how long it is.....I've seen the old farmers trick of cutting the pickup tube off shorter when a tank gets rusty and trashy inside to keep from pumping junk thru the carb....
10-02-2019, 09:31 AM | #4 |
Re: 1957 gas tank
Original?
10-02-2019, 10:00 AM | #5 |
Re: 1957 gas tank
Oh, sorry no. I was referring to under bed tanks.
10-02-2019, 01:03 PM | #6 |
Re: 1957 gas tank
My question is what size are original behind the seat tanks, 14/15 or 17?
10-02-2019, 01:46 PM | #7 |
Re: 1957 gas tank
flat tanks are typically 15-17 gal
step up tanks are 20-25, mine is 22 gal i believe. step up tanks require the rear x-member moved i run out of gas with a 16 gal fill, go figure
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
