Old 12-29-2019, 08:27 PM   #1
projectking
projectking's Avatar
V8 np435
Anyone running this combo in their truck? Its in the v8 position and the high hump doesn’t work, looks like I need to use the I6 location for the engine mounts and move the trans crossmember back accordingly.
Not a common combination, the trans was previously behind a GMC 305 V6.
Thanks,
Jon
68 GMC C3500 Longhorn DRW
67 Chevy C10 LWB
90 Mustang Gt
90 Mustang Notchback
projectking is offline   Reply With Quote
Old 12-29-2019, 10:07 PM   #2
Astro-Balls
Astro-Balls's Avatar
Re: V8 np435
I have the Big block and NP435.
Motor mount location shown here.
1968 C20 Fleetside 396 4sp PS PB AC CST
https://www.youtube.com/watch?v=RWK8GgWD4uA
Astro-Balls is offline   Reply With Quote
Old 12-29-2019, 10:30 PM   #3
projectking
Re: V8 np435
Rectangular hole in the high hump?
67 Chevy C10 LWB
90 Mustang Gt
Old 12-29-2019, 10:46 PM   #4
Astro-Balls
Re: V8 np435
Yes,High Hump With rectangular hole.
Here is a pic before I install the shift boot.
Old 12-29-2019, 11:00 PM   #5
projectking
Re: V8 np435
Mine is further back in the flat portion of the cover. I’m betting I’m going to need to move the engine. Thank you for the pics!
67 Chevy C10 LWB
90 Mustang Gt
Old 01-01-2020, 05:56 PM   #6
projectking
Re: V8 np435
Engines now in the I6 location(V8 stands) and the high hump still won’t work, this engine and trans was in my C3500 but had been relocated in the frame after the V6 wore out, I’m wanting it in the right spot...hopefully someone on here has a V8/NP435 to confirm and tell me if I need the high hump like Astro’s
67 Chevy C10 LWB
90 Mustang Gt
Old 01-02-2020, 12:33 AM   #7
Astro-Balls
Re: V8 np435
Post some pics of your trans and bell housing, Engine mounts.
Old 01-22-2020, 12:34 PM   #8
Willys_MB
Willys_MB's Avatar
Re: V8 np435
Here are pics like you requested.
I figured I should respond in your thread and not the other one so that if someone else has an issue they can find the answer easier. My T-Hump looks just like the one that the guy with the big block posted. Looks like it's in the front holes. If you need pics of the transmission crossmember let me know and I can get those, too. Maybe you need a different bellhousing or something. I can get any pics you need!
1968 GMC C2500 Long Bed Fleetside
Willys_MB is offline   Reply With Quote
Old 01-22-2020, 12:45 PM   #9
projectking
Re: V8 np435
Thank you! I’ll move it back to the front holes and track down a square hole cover like the one you guys have. My trans was bolted to the crossmember in the front position. I appreciate the help!
67 Chevy C10 LWB
90 Mustang Gt
Old 01-22-2020, 01:22 PM   #10
Willys_MB
Willys_MB's Avatar
Re: V8 np435
No problem! It seems to me like the NP435 isn't a very popular transmission, so if you ever need anything let me know. I'm not an expert by anyone's definition, but I had a heck of a time working with it during my engine swap. Good luck finding a high hump!
Old 01-22-2020, 01:39 PM   #11
projectking
Re: V8 np435
Worst case it will get a 2wd 4 speed hump with the larger hole(mines a ‘67 small oval). It seems like a better geared trans compared to a 465 is why I decided to run it. Do you have any idea what flywheel you have?
67 Chevy C10 LWB
90 Mustang Gt
Old 01-22-2020, 02:25 PM   #12
Willys_MB
Willys_MB's Avatar
Re: V8 np435
I ended up needing a new flywheel and clutch, so here's what I bought. It's worked out well so far, but I've only got 10-15 miles on the build right now. Just waiting on a new fuel line and then I'll be driving it every day the weather allows!
Here are the parts I used as listed on Rock Auto. Not sure how to post a link to just the one part, but you can search the part number in the brackets and it'll come up.
Flywheel - PERFECTION CLUTCH 506504 {#3991469} - $79.99
Clutch Kit - PERFECTION CLUTCH MU90911 {#90681} - $65.79
Old 01-22-2020, 02:27 PM   #13
Willys_MB
Willys_MB's Avatar
Re: V8 np435
I should probably say that I compared it to my old one (counted the teeth) and it was identical.
Old 01-22-2020, 02:36 PM   #14
Wrenchbender Ret
Re: V8 np435
I would not waist time on a NP435. The Sm 465 is a much better trans.
George
Wrenchbender Ret is offline   Reply With Quote
Old 01-22-2020, 02:50 PM   #15
projectking
Re: V8 np435
George
No thanks, I like having a useable 1st gear.
67 Chevy C10 LWB
90 Mustang Gt
Old 01-22-2020, 02:51 PM   #16
projectking
Re: V8 np435
What was the PN on your old one, if you still have it?
67 Chevy C10 LWB
90 Mustang Gt
Old 01-22-2020, 03:07 PM   #17
Willys_MB
Willys_MB's Avatar
Re: V8 np435
I don't have it anymore, but it looked to be the original flywheel based on age and it was a GM part. The cracks and valleys were kind of scary; as soon as I got the new one and verified fit, it went in the trash.
Old 01-22-2020, 03:37 PM   #18
projectking
Re: V8 np435
WOW! I was just wondering because the same PN was on a ‘67 292/420 and a ‘76 350/465.
Thanks again for your help/info!
67 Chevy C10 LWB
90 Mustang Gt
Old 01-22-2020, 03:50 PM   #19
Willys_MB
Willys_MB's Avatar
Re: V8 np435
Any time, if you ever need anything else give me a shout!
