10-19-2018, 08:10 PM | #1 |
1972 Blazer undecided!!
Here is the pic of the blazer i picked up today!! It was a 4x4 someone converted to a 2-wheel drive!!! If you notice i have a 4-wheel drive frame and suspension sitting next to blazer!! hopefully i get to start on it in the next month or so and i will post more!!!
10-20-2018, 04:52 PM | #2 |
Re: 1972 Blazer undecided!!
Alright! What are the plans for this one? Full resto back to stock or adding some modern comforts?
10-20-2018, 08:51 PM | #3 |
would like some ideas!!! I think 4x4 is the option!!!!
10-23-2018, 01:39 PM | #4 |
Is a budget a concern? Skills for larger changes? Time?
Real easy for internet folks to throw out crazy ideas you may not have time/money/skills to pull off. Big difference in me saying CUMMINS SWAP vs GM Goodwrench 350 haha. |
10-23-2018, 04:57 PM | #5 |
Money is definitely an issue!!!! But going to make it a 4x4 again and sell the other frame and 2-wheel components!!! Probably going to try LS-7 this time and make some other modifications!!! This may be the one I keep but it may take a little bit do to trying to finish up new house and old horse barn I am turning into my garage!!
10-23-2018, 06:40 PM | #6 |
I have 3 of these now. At one point I owned 7. Don't judge - I like these rigs.
1972 Chevy Blazer - factory 2wd 1970 GMC Jimmy - 2wd converted from 4x4 1971 Chevy Blazer - 4x4 I like them each in a different way. If you want to go back to complete OEM specs based on the SPID- those usually have the best return on money - should you ever decide to sell. Either way you go - it seems like solid examples of these trucks are going up in price. |
10-26-2018, 03:53 PM | #7 |
Starting the tear down!!!!
10-27-2018, 04:15 PM | #8 |
yeah -
11-08-2018, 06:36 PM | #9 |
sweet project!
1970 Base Step Side Dark Olive 250 3ott restoration 1972 k5 4x4 250 3ott project 1970 long bed light olive 283 th350 driver SOLD |
11-08-2018, 10:33 PM | #10 |
Im in to see this one . One day I will own a Blazer ,know where an original untouched one is . I have a lot of Chevelle friends up in Ohio ,hope to go visit next august .
12-25-2018, 01:15 PM | #11 |
Got a lot of the new metal to get started!!!
12-25-2018, 05:10 PM | #12 |
Nice - that should save you quite a bit of time on body work for the rear half!
Which supplier did you go with? |
12-28-2018, 09:04 PM | #13 |
I tired southern Kentucky classics this time!
12-28-2018, 09:07 PM | #14 |
12-28-2018, 09:17 PM | #15 |
Well, I'd say you got it apart! Are you going back 2wd or 4wd?
Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer '70 GMC Jimmy 2wd |
12-29-2018, 05:35 PM | #16 |
going back 4x4!
12-30-2018, 03:17 PM | #17 |
Carpe manana
Back to 4wd? Nice!
01-16-2019, 08:32 AM | #18 |
Getting started with body and suspension! Hopefully this turns out first time to do this much!
01-16-2019, 04:51 PM | #19 |
Just keep everything loose to confirm alignment before final welding and you should be good. Keep the pictures coming so we can follow along!
01-17-2019, 11:41 PM | #20 |
Rock on! Following with great interest.
You ever have one of those mornings where you wake up owning more trucks than you did the night before? 1972 K5 1972 K10 1967 K20 bucket truck |
01-24-2019, 08:42 AM | #21 |
Starting to put body panels together and so far just have one quarter and inner fender on and had to do a little trimming on rear floor pan to get quarter to attach! Also received my new springs did a 2" lift. Hopefully can get front and rear end back today so I can get it on the skates to move away from wall to start on other side!
01-24-2019, 10:49 AM | #22 |
Nice way to start a build, new metal. curios to see how it bolts up?
01-25-2019, 08:34 AM | #23 |
I got the axles back today and everything inside had to be replaced(Everything) so I started to put back under blazer to get it back on wheels and start the build.
02-06-2019, 09:59 AM | #24 |
Started working on getting quarters on and ordered the lower piece that connects to the rear floor and the front floor pan and hopefully can start getting this together! Picked up a set of rally wheels that I may put on it!
02-07-2019, 10:49 PM | #25 |
the plate you are waiting on (the step up from the front floor to the bed) needs to go on before the bedsides get fully installed. So steps would be:
Looks good so far! |
