09-12-2017, 11:05 AM | #1 |
How To Install and Remove Hubcaps Without Damaging Them
Does anyone have a method for installing and removing dog dish hubcaps that prevents them from being damaged in the process?
I've seen several sets of NOS hubcaps go for good money and I can't help but wonder if they will ever be installed since they seem to be so prone to denting or splitting during the installation or removal process. |
09-12-2017, 02:09 PM | #2 |
Re: How To Install and Remove Hubcaps Without Damaging Them
There are usually 3 nubs with 2 close together, put cap over those 2 first and tap cap over the single nub. Do it any other way and it takes more force and stretches the cap
09-12-2017, 02:20 PM | #3 |
Chris, I had my stock wheels powder coated and installed a set of copo caps. When I went to remove them I was afraid of damaging them so I went to my tire store , Les Schwab and bought a hubcap removal tool ! Cheap $13.00 worth every cent....jack
71 C-20 07 Magnum RT AWD |
09-12-2017, 02:48 PM | #4 |
Jack, any pictures of the tool you picked up? We don't have Les Schwab's in my area. So, the tool doesn't damage the edge of the caps or the finish on the rims?
Thanks for the for the info Randy. My wheels have 4 nubs. Any Advice on how to put caps on those? Here's a pic of one of my wheels. |
09-12-2017, 04:14 PM | #5 |
I've always pulled them off by hand on my 67, I guess after 50 years they're pretty broken in.
09-12-2017, 10:13 PM | #6 |
Ok, let's assume I'm talking about NOS (undamaged) caps and freshly repainted steel wheels. Any other tips to keep them from being damaged during installation and removal.
Other than not installing them in the first place. |
09-13-2017, 10:11 AM | #7 |
laying low
Volkswagens used to have a u shaped wire that you placed over the tire tool and fit in two small holes on the edge of the cap. It made easy work of removing the cap. A rubber mallet used to be the go to tool for installing the caps and full covers without denting them.
A similar wire loop could be used for most any hubcaps by drilling two small holes on the edge of the caps.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross Last edited by Boog; 09-13-2017 at 10:24 AM. |
09-13-2017, 11:35 AM | #8 |
I will take a photo of the tool, if you need I can get you one and ship it to you...Jack it works great
09-13-2017, 12:10 PM | #9 |
I use the harbor freight trim/molding removal tools, they work great:
https://www.harborfreight.com/5-piec...set-67021.html |
09-13-2017, 12:13 PM | #10 |
Carpe manana
I use one of these US made removal tools (I don't have the exact model number at the moment): https://www.amazon.com/dp/B000MIWLXO..._t1_B00GWFOSBY
09-13-2017, 12:39 PM | #11 |
I use a tiny metal pry bar and a thin piece of scrap leather for protection.
Works great! Powder coated wheels and caps. To install, I pop them on with the side of my fist, hitting them on the edge where they're stronger. Low tech, low cost options that work.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. |
09-14-2017, 06:50 PM | #12 |
I bought the same tool !
09-14-2017, 07:12 PM | #13 |
I install the same way as slikside - hammer the caps on with the heel of my closed fist, on the side of the caps, where they are strongest. 4-nub wheels, freshly powdercoated. I do have the '73 caps, though (I painted the bowties blue), and I understand they may be a stronger material.
To remove, I simply took a slim piece of round aluminum stock, bent one end into a crude handle, hammered the other end flat, wide, and rounded on an anvil and then bent that flat piece to 90*. To remove the caps I just insert the flat edge and pull sharply on the handle. No damage to wheel or cap. Free if you have random metal lying around like I do.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
03-28-2020, 02:16 PM | #14 |
"Trucks with Class"
Cheap Chinese tools: Don't pry! Wide blade & small slide hammer saves the edges. Cut them down for deeeeep wheels.
