10-20-2020, 09:20 AM | #1 |
L31 Vortec in a 66 - temp sending unit questions
I have been told to check with A1971Blazer about turning down a temp sending unit so it will fit my engine so I have sent a pm to him on that. I wondered if others who have rewired with American Auto Wires kit 500560 needed anything else to make the connection needed to the harness?
https://www.summitracing.com/parts/AWW-500560 Will the stock temp gauge in the cluster work right with this setup? Also, is there a best temp sending unit brand to get? |
10-20-2020, 03:25 PM | #2 |
Re: L31 Vortec in a 66 - temp sending unit questions
I purchased a sending unit from Letric Limited when I went from warning lights to a temp gauge. With a 180* Tstat, the needle is right about in the middle of the green. With a 195* Tstat, the needle will sit towards the H side of the gauge, but still in the green. I have not had any overheating issues with the truck.
On getting it to work with your engine, I'm not sure what needs to be done. For me, I had an intake manifold that did not have the correct size NPT threads. I took the intake to the machine shop that rebuilt the engine for my Dakota and had them drill and tap for the stock sender.
Christian Carpenter 1963 C10 - Frankentruck 283, Muncie 3 speed with overdrive Overdrive wiring here1963-ish truck bed trailer - Half-Wit 1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed 1995 Dodge Dakota Sport "I'll put it simple: if you're going hard enough left, you'll find yourself turning right." - Doc Hudson |
10-20-2020, 10:48 PM | #3 |
60-66 Nut
If you want to use the stock gauge, you must use the correct stock sending unit.
10-20-2020, 11:28 PM | #4 |
Captain, from what Im reading in other posts this is the one then correct?
https://www.rockauto.com/en/moreinfo...98816&jsn=1892 And if so would placing it in the intake that is 1/2" NPT do the job? Or is the block the only way to get an accurate read? |
10-21-2020, 09:53 AM | #5 |
The intake is where GM put it, so that will be ok for you too. I have mine in my intake and it works great
10-21-2020, 10:15 AM | #6 |
Thanks Christian, Ill order it and place it in the manifold.
