10-17-2020, 12:09 AM | #1 |
35" KO2's on a 72 K10..what pressure do you run?
Just wondering what tire pressure to run in my 35 x 12.5 KO2's..
Currently running 26 PSI and they look crowned. When I pull into my shop the concrete dust covers about 10" of the 12.5 width. Whatcha running in yours?
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
10-17-2020, 09:30 AM | #2 |
Re: 35" KO2's on a 72 K10..what pressure do you run?
sounds good via the dust cover . you want about 3/4 coverage .
my old 38" bias swampers i run 25 psi and had good wear and ride .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
10-19-2020, 09:45 PM | #3 |
I run the 35" AT's on my Jimmy at 24 psi.
10-24-2020, 10:55 AM | #4 |
All about them K’s
25lbs here for my 35” Mickey atz’s
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 |
10-28-2020, 06:59 AM | #5 |
i'm going to have to look at mine and see what it recommends for psi
I'm running 36 psi for every day use . |
